Page 3 of 4 FirstFirst 1234 LastLast
Results 21 to 30 of 38
Thread: HF Captured Rig in 4 Hours
  1. #21
    Arena, Wisconsin
    231
    Stu, I can see how the 8mm rod is expedient at this stage, but I expect that you will decide to drill, harden, and temper tool steel cutters eventually. As suggested, the ability to index a square cutter or rotate a round disc is invaluable.
    As to that angle grinder thing… once we got in a load of schedule 40 pipe that was so out of round it wouldn’t slide into its mating part, so we rigged an angle grinder (hose clamped it), onto a plate attached to the cross slide of a lathe, and had relatively unskilled workers true it up enough to fit a gage.
  2. #22
    Stu, you were looking for material for cutters. Have you considered a piece of lawnmower blade or a large spade drill bit.
    Turning makes the world go a'round
  3. #23
    14,239
    Donald, both great sources of steel, both I do not have!
    I can buy some SUM24L steel here, which is a HSS for fairly reasonable prices, I'll go that route.
  4. #24
    Quote Originally Posted by Bernie Weishapl View Post
    Stu that is a good looking rig. I just wish I had the time and equipment to do that. If I built tools I would never get any turning done. With my full time job, my clock repair shop and then trying to turn I need a 54 hr. day.
    Stu it is a beauty and looks like it does the job.
    I just don't get it . Where does Stu find the time to do all that he does
    George
  5. #25
    14,239
    Quote Originally Posted by George Conklin View Post
    Simple really, 5 little words.................
    "I do not watch TV"
  6. #26
    Wake Forest, NC
    292
    No TV at all? Shame..... Well, maybe not. Only shop time I get is when the kids are asleep. I watch two or three shows (one kiddie show with my daughter), but not much.
  7. #27
    Richard Smith Guest
    Ummh I'm just dropping in on this conversation. So forgive me if I'm way off. Have you tried useing those ceramic inserts? It would save a lot of work making little metal inserts.
  8. #28
    Goodland, Kansas
    4,742
    I don't have a clue George. I don't watch TV at all and I still need a 36 hr. day to do what he does.
    Bernie W.
  9. #29
    14,239
    Quote Originally Posted by Richard Smith View Post
    Richard, please drop into any conversation we are having, anytime!
    Ceramic inserts, I'm not sure I follow, are you talking about the cutting part of the tool?
    I do not know if "Ceramic" would hold up, are they not somewhat brittle????
    If you have an example, please do tell, I'm all ears!
  10. #30
    14,239
    Quote Originally Posted by Travis Porter View Post
    OK, I'll fess up, on about every second Sunday, at 7 PM here, there is a show called "Testuwan Dash" that is an hour long, my daughters, my wife and I will often all sit around watching it, it is fantastic. I guess I watch about 2 hours a month.
    It is really easy, Japanese TV SUCKS, sports, you want sports............ OK take your pick Soccer or Baseball..........
    The don't even run the MotoGP here on TV until a week after the race is over and at 2 or 3AM........ (my other hobby is motorcycles).
