Results 1 to 10 of 21
Thread: Some times I think I should not have contributed to the gene pool
    Tampa
    281
    It was enough to ruin my summer.
    I have been working on my kitchen island and all has been going like a charm until I was routing the raised panels for the four large drawer fronts.
    I edge glued the panels using biscuits....yup, you guessed it.... The darn biscuits showed up on the edge of all the boards.
    Not sure how to fix something like that short of new boards.
    I may just leave it like that.
    Soon as I find the memory stick I will post photos.
    13,437
    Ouch!
    Might be able to do a shallower face cut and do a deeper back cut.
    new york city burbs
    10,188
    either make a new front, ofcourse you know that, or chisel out the biscuit carefully.(I just had this problem on the bartop I made, but not as visible as a drawer front)
    After you chisel out the biscuit, cut a piece of wood the same grain orientation and tap it in place with a bit of glue. After its nice and dry, sand it down. Once finish is applied, at least it will blend in same color and wont be as noticable as a white slice of different colored wood.
    Im an amateur, but where I did this it was just about not noticed. hope this helps somewhat. Just an idea.
    13,437
    Nice solution Allen!
    Might be able to just run through the shaper if it's still setup too.
    Tampa
    281
    Thanks Allen, I will probably do something like that. I still have about 3" of board from that same piece and your solution might just work.
    Thanks again.
    NH
    4,005
    Than the next thing to do is sell the bisque joiner.
    Stupid hurts.
    Tampa
    281
    I wasn't going to use the biscuits but it seemed like a good idea. I didn't use them on the island panels and they came out nice. I don't know why I used them on this...
    NH
    4,005
    Quote Originally Posted by Julio Navarro View Post
    But now you know why not to.
    Stupid hurts.
    Tampa
    281
    I'm an expert now.
    5,319
    Allen's solution is best - short of making all new panels. Done right, it'll be nearly invisible. Use hide glue instead of the yellow stuff, though. It'' show less under finish.
    As for the biscuit joiner - after many years of varied usage, the only things I ever use it for now are to reinforce miters, and to install face frames on cabinet carcases. For glue-up alignment, I find biscuits useless, and it's been proven many times over that a plain glue joint, properly done, is stronger than the wood itself, so why mess with biscuits?
  1. Measure Twice, Cut Three or Four Times
    Last Post: 06-27-2015, 05:55 AM
  2. some times you just need to walk away...
    Last Post: 04-01-2013, 01:59 AM
  3. Victim of the Times....
    By Sean Wright in forum Off Topic Discussion
    Last Post: 04-07-2011, 11:56 AM
  4. HB2U Frank Fusco, Gene Miller & Robert Koster
    By Rennie Heuer in forum Off Topic Discussion
    Last Post: 10-27-2009, 01:40 PM
