Results 1 to 4 of 4
Thread: Pocket door and electrical in 2x4 wall.
    Jan 2011
    Tacoma, WA
    274
    Is there a way that you can fit a pocket door and a light switch in the same 2x4 wall? Do they make low profile boxes and switches?
    So the switch would be in the same area as the door pocket.
    Trying to get around having to move the switch to the other side of the door.
    Thanks!
    That's not even a smile! That's just a bunch of teeth playing with my mind!
    London, Ontario
    3,383
    Quote Originally Posted by Brian Altop View Post
    Thanks!
    I moved the switch when I did it.
    There are surface mount wiring kits, but I don't care for that look in living space.
    The pocket door kit pretty much fills the entire 2x4 cavity. The kit goes in, and then you put on the drywall. There was no extra space. You also need to be careful when installing your trim and drywall, so that your fastener's don't go too deep and scratch the door.
    Puyallup, WA
    330
    Brian,
    I'm with Art -- when confronted with the situation, I moved the box location. Whether it's physically possible or not using a shallow box is one thing, whether it's to code is another altogether.
    Jan 2011
    Tacoma, WA
    274
    You guys are so mean. Now I have to move the wiring to the other side of the door.
    Thank you for the advice!
    Also thanks for the advice on the depth of nails, I didn't even think about that one! This will be my first pocket door installation, it should be fun.
    Brian
  1. pocket door problems - RESOLVED!
    By Carol Reed in forum Carpentry and Construction
    Last Post: 11-24-2014, 03:08 PM
  2. A Colonial Wall Pocket
    Last Post: 11-05-2013, 12:38 AM
  3. Wall Hanging - IT'S FINISHED and not a wall hanging anymore!!
    By Jeff Bower in forum Lathe Project Showcase
    Last Post: 09-21-2010, 03:43 PM
  4. Pocket Door Question
    By Tony Falotico in forum Carpentry and Construction
    Last Post: 05-16-2008, 10:54 AM
  5. Pocket Door Track Recommendations
    By Jeff Wright in forum Carpentry and Construction
    Last Post: 06-26-2007, 04:10 PM
