Results 1 to 3 of 3
Thread: Grinder Stand
    Monroe, MI
    470
    Thumbs up Grinder Stand
    I just finished up this grinder stand tonight. Its not woodworking, but if you have a welder, a friend with a welder, or can find a local welding shop, this is inexpensive in the parts department. The base is a 14" steel wheel. The column is an old column out of my parent's basement (they had to replace them all because the bottom 1-2" rusted out. The top is a piece of 3/8" thick plate. The column happened to fit inside the center hub of the wheel perfectly so I just welded the column to the wheel (outside of the wheel facing down) and welded the top on. I then mixed up a bag of concrete and filled the wheel cavity. Finally I filled the column with packed play sand from the bottom and capped it with a round oak plug driven in with a mallet. The only vibration comes from the fact that my floor and/or the wheel aren't perfectly flat. I plan to fix that by putting some pieces of rubber under the wheel strategically place to make it rock-free.
    BTW, the wood is just to hold it off the floor since I put another coat of paint on the wheel tonight.
    Eastern Panhandle of West Virginia
    103
    Thumbs up
    .... Good idea Matt, I have often thought of doing something like that and probably still will. The thing I like about it is, it's portable. You can take it to the job if necessary .
    Good job
    Quote Originally Posted by Matt Meiser View Post
    Thinking about a project without ACTION is just DAY DREAMING .
    15,811
    Hey Matt, I used to have one just like that!
    Better than any stand you can buy for sure, nice job!
  1. Grinder Stand, Small Scrap Storage, Cleat Fixture
    Last Post: 01-31-2015, 03:21 AM
  2. New grinder
    By Don McFarland in forum General Woodturning Q&A
    Last Post: 05-04-2013, 09:35 AM
  3. New Grinder ...not
    Last Post: 02-16-2012, 01:39 AM
  4. New Double Decker Grinder Stand Build
    Last Post: 12-06-2008, 07:00 PM
  5. Cast Grinder Stand
    By Dan Mosley in forum Old Iron
    Last Post: 11-10-2008, 04:25 PM
