Results 1 to 7 of 7
Thread: Searching for
    3,134
    Searching for
    A bushing to enlarge a electric motor shaft from 5/8" to 7/8" do they make one & if so where can I find it? Thank you.
    13,433
    What's the application on? Is this a bushing to go directly over the shaft (1/16" thick) or to transition from one shaft to another?
    3,134
    It will be installed on a 5/8" motor shaft with a key way so that a 7/8" pulley with a key way may be mounted on the shaft to drive a wood lathe.
    Floydada, Tx
    1,941
    I have a machine shop that I use for this stuff. Usally something like that would cost me about $10. The only bad thing is they hand me a mic and point me to the scrap pile and tell me to go dfind a peice for them to turn.
    3,134
    Quote Originally Posted by Al killian View Post
    He He Ha Ha what are you waiting for HMMM? I'm not so lucky.
    Jan 2011
    3,798
    Monroe, MI
    470
    McMaster Carr has 5/8 to 7/8 bushings. You'd have to use an abrasive wheel or some other method to cut a slot to match the keyway. They also sell stepped key stock since I'd assume the keyway in your motor shaft will be a different size than the keyway in the pulley.
    Is there something special about the pulley? Wondering if it would be better to just buy a pulley with the proper bore? Could be expensive if its a stepped pulley though.
  1. Searching New Posts
    By Peter Rideout in forum Site Questions and Test Posts
    Last Post: 11-02-2011, 12:50 AM
  2. Searching for pictures
    By Rob Keeble in forum Site Questions and Test Posts
    Last Post: 09-18-2011, 04:02 PM
  3. searching
    By Mark Kosmowski in forum Site Questions and Test Posts
    Last Post: 10-27-2007, 11:02 AM
