Results 1 to 10 of 14
Thread: Heavy wood rack needed
    Floydada, Tx
    1,941
    Well today we found the limit of the one lumber rack. We had what we thought would be a great design, well maybe it was just not meant for waht we put on it. Anyway, we bulit it using 2x4s stading parrell and then vertical ones in between and everything bolted together. Well i gues 4'tall x 18"of red oak and maple stacked on the two shelfs was to much and tonight it turned into splinters.
    OK anyone have ideas for the next one? I have been thinking of building it more like the lumber yeards using 2x6 and lay the boards on that with 4x4s in the corners.
    North West Indiana
    6,099
    I welded the one in the wood shop about twenty years ago. 1 1/2" thick wall pipe welded together.
    Jon
    I too use a heavy steel framed set of shelving.
    It currently holds about 500 bd ft of hardwoods without a single groan.
    If you are going to use wood, I wouldn't use 2x6. I'd use 2x10's !
    Jun 2010
    3,220
    Al, I'm sure you know more about what you're doing than I ever will, but this is what I built, and it's got a few hundred pounds on each shelf....
    AKA The Rookie
    9,077
    Sounds like it was weight per shelf and not overall weight that may have got you. The same load and design using 5 shelves instead of two may have been OK. I keep my "arm" spacing to 6" as I don't like to dig for what I am after but, your stack sounds more like a volume issue than an accessibility issue. If the arms were the only thing that initially failed I would go with a similar design and more arms.
    Here ya go
    this came up just the other day and here is one guy's solution and why he chose what he did.
    Mar 2010
    Decatur, Alabama
    518
    What was your spacing between supports? Twice as many uprights, and you're going to be able to hold roughly twice the load.That's pretty important, also how long are the arms.
    Holding a load at 18" center from the upgright is 3x as hard as holding it 6" away from the upright.
    Do you think the upgrights failed, or the "arms" that were holding the wood? Using more shelves with 1/2 the weight of course helps there.
    In my opinion, using 2x6 for upgrights isn't going to buy you much at all over the 2x4's if they're failing at the joints. increasing the number of upgrights per foot of shelf, more shelves with less load, etc will help a lot more
    May 2008
    Deming, NM
    42
    Splinters? Wish you hadn't told me that!
    Oh well, this one is 27 years old and still standing. First I built the plywood rack, and added a top for a place to store stuff. When the wood pile got kinda big, a second story was added. It is supported with six 2x4s that run to the floor, so no additional weight is on the original rack.
    NH
    4,012
    It sound like the 2x failed on the bolts Solid blocking to the floor would have solved that.
    Stupid hurts.
    May 2011
    Cape Cod, Ma.
    1,553
    What about using some 4x4's drilled through every 10 -12" to accept a length of galv. pipe to act as the shelf supports then frame accordingly to keep it tied into the floor and ceiling. If you have the room use 5'pipe that way you have a bit over 4' between the posts and can store sheet goods as well. This set up can be expanded as needed. collapsed when not needed and moved easily (when not loaded) plus by using multiple shelves you would spread the load out more as Glenn mentioned.
  1. NTM (New to me) Wood Rack
    Last Post: 02-13-2012, 07:00 AM
  2. Heavy Duty Wood Workers Bench
    By Tom Hoffman in forum General Woodworking Q&A
    Last Post: 07-03-2011, 03:24 AM
  3. tough day today, scrap wood, glass guy, heavy rain
    Last Post: 07-08-2009, 12:05 AM
  4. heavy wood furntiture=shipping?
    Last Post: 05-14-2008, 12:27 AM
  5. Wood Rack Done
    By Bob Spare in forum General Woodworking Q&A
    Last Post: 10-08-2007, 12:54 PM
