Results 1 to 5 of 5
Thread: Handplane finish / raising the grain
    Jun 2010
    Boston, MA
    145
    On my recent cradle build I tried using my handplane to get the "finish ready" surface on the hard maple.
    Everything looked great until I applied the water based dye. I got enough grain raising that I had to knock it down with some sandpaper.
    I figured I'd check and see how other folks handle this before I begin experimenting.
    Is sanding a planed surface after raising the grain the best way to go? Or do folks try to scrape/plane off the fuzzies without cutting too deeply? Or is there some other technique I should try?
    -Matt
    You could use a card scraper or sandpaper whichever you prefer. I use sand paper usually 320 grit. I use a lot of water based dye's.
    Apr 2009
    Outside the beltway
    5,250
    there are 2 ways to defeat this problem on maple, 1 you use a damp rag and rub over the maple to quicken the drying use a blow dryer, then sand and repeat 2 or 3 times. 2 use a pre stain 1st before applying the stain.
    I prefer the damp rag method myself and then a scraper razor blade or a medal scraper.
    ::: Andrew Wyeth :::
    colonialrestorationstudio.com
    Aug 2008
    Reno, Nv
    3,632
    Hey Matt, almost any water or alcohol based finish is going to raise grain...dyes included. One of the downsides
    Jun 2010
    Boston, MA
    145
    Thanks for all the replies.
    Isn't it amusing that all the articles in the magazines that talk about getting a "finish ready" surface with your hand plane don't address the issue of raised grain.
    I think I'll try using a scraper to clean off the fuzzies on a couple of cutoff scraps. If I can't get the hang of it, sanding with the 400 grit after raising the grain gave good results on the cradle.
    -Matt
  1. open grain vs. closed grain hardwoods
    Last Post: 04-09-2011, 02:35 AM
  2. Barn Raising - ALL moved in
    By Ned Bulken in forum Carpentry and Construction
    Last Post: 08-01-2010, 02:13 AM
  3. Vertical Panel Raising Bit - trying them out
    By Art Mulder in forum General Woodworking Q&A
    Last Post: 12-03-2008, 11:36 PM
  4. Raising a house
    By Tom Hoffman in forum Carpentry and Construction
    Last Post: 06-02-2008, 01:34 AM
  5. Raising Young Woodworkers
    Last Post: 10-09-2007, 09:48 AM
