Results 1 to 10 of 17
Thread: Project: Outfeed Table
    Monroe, MI
    470
    Finally got around to starting on a new outfeed table for my saw today. Previously I had a set of cabinets. I moved the cabinets to be the base of my miter saw because I wanted something smaller for the outfeed table. Then I realized that my old Stablemate miter saw stand never sold and had a lot of nice looking steel tubing. So I disassembled it and started welding up this frame.
    Originally I was going to drill holes in the back rail of my Bies. fence. Then I came up with the idea to clamp it in place for easy removal. Two small C-clamps with the heads ground down to fit through a 1/2" hole were perfect clamps. I also made adjustable feet for leveling the table as needed.
    The top is going to be 3/4" MDF with laminate. I'm trying to decide if I should add a cross-brace to the center of the top to support the MDF better? Or maybe just a 1x cleat on the bottom?
    Attached Thumbnails Attached Thumbnails IMG_7939.jpg   IMG_7940.jpg   IMG_7941.jpg
    Punta Gorda, Florida
    902
    Nice job Matt! Great idea about using the C clamp like that. It looks like that your outfeed table is a bout 24" x 40" or so. If it were me and I had one more piece of steel tubing I would weld one more lengthwise across the 40" span and that would support the MDF ever 12". I think that would do it. I think that you are right about worring about it sagging with no additional braceing.
    Odessa, Tx
    1,813
    Matt, I agree with Allen, and if you can fit one in, in the "Long" direction, (I guess you would call it the width), of the table where it won't interfere with your motor when you tilt the blade, I would definitely put one in there. The problem is that it gets kind of weak and wants to sag after you rout the slots for the mitre guage bar or cut off sled's guide bars. One other thing that might be useful would be to drill a hole through your table frame's square tubing down through the Biese's angle iron and then slip an alignment pin in each hole and tack weld the pin in the table frame only. It would still be easy to remove by removing the clamps and just lifting enough for the pins to come out, but would make it real easy to mount again without having to align the mitre slots each time. (If you do put the pins in, be sure to grind a bevel on the end so they will slip into the holes in the angle easily)
    It's looking good so far.
    Monroe, MI
    470
    OK, I added a piece the long way. I didn't have a piece long enough, but I did have a piece that was close and a cutoff that would make it long enough when I welded them together. I was going to look at adding some pins as suggested by Norman, but then I realized that I made it so that it butts against the tube from my Bies. guard (the off-white tube in the first picture) so I already have alignment built in with no additoinal effort
    Right now it is in the spray booth getting a few coats of some grey clearance spray paint I've had in my cabinet for a while.
    Michigan
    2,436
    Good advice was given on making sure the tilt won't get in the way, wish I'd have had it when I made mine.
    ...of course it was right in the way when I tilted the arbor.
    Monroe, MI
    470
    I'm ok on the tilt as long as I don't have the blade fully raised and fully tilted. In that case, there is slightly less than 3/4" clearance between one of the capacitor covers and the plane of the saw's table top. If worse comes to worse I can create a gouge to accomodate it in the underside of the outfeed table top. I don't expect it to be a problem though since it wasn't a problem with my previous outfeed table.
    I also found out today that I may be able to get some old work surfaces from my work this week which might work well for the top. The health and safety director says we have to clean out the off-site storage unit. Apparently old furniture stacked 8' high is unsafe?
    Here are a couple pictures related to my previous post. Oh, I also started working on getting my router mounted in my extension table. If you look closely you can see how to repair the OOPS! that occurs when the set screw comes out of the bearing retainer and allows the bit to dig into the template
    902
    Quote Originally Posted by Matt Meiser View Post
    When I built my router table the same thing happened to me. I really check the set screws now.
    The center bar that you added looks good. That should do it.
    Odessa, Tx
    1,813
    Quote Originally Posted by Steve Ash View Post
    How do you think "I" came up with that suggestion, Steve? I did find that a "HF" Sawzall was a good adjustment tool though.
    Monroe, MI
    470
    I finished up the outfeed table today. The top is 3/4" MDF with some clearance-sale laminate. I used some heat sensitive edge banding to dress up the top a little.
    I also mostly built my router fence today. Just need to add some dust collection.
    Attached Thumbnails Attached Thumbnails IMG_7944.jpg   IMG_7945.jpg   IMG_7946.jpg   IMG_7947.jpg
    902
    Neat job Matt! In fact, your whole setup is neat. Allen
  1. a really nice outfeed table for my TS
    Last Post: 10-29-2012, 04:36 PM
  2. Outfeed table help, please
    By Jonathan Shively in forum General Woodworking Q&A
    Last Post: 01-05-2010, 09:27 PM
  3. Outfeed/assembly table finished!!
    By Craig Johnson in forum Jigs and Fixtures
    Last Post: 01-17-2009, 02:40 PM
  4. outfeed table miter slots
    By Craig Johnson in forum General Woodworking Q&A
    Last Post: 12-24-2008, 04:57 PM
  5. Show Me Your TS Outfeed Table!!!
    By Rob Bodenschatz in forum Jigs and Fixtures
    Last Post: 02-27-2007, 10:55 PM
