Results 1 to 10 of 16
Thread: Hot Dog Tote for LV Low Angle Jack
    9,077
    I had prepared a blank along the lines of Derek Cohen's examples to take down to dad's during a belated Mother's Day visit. While my brother helped dad install his replacement PC and LOML and her mom chatted it up with my mom . . . I snuck off to dad's lathe for about a half hour.
    This is only the third thing I've ever turned so be nice:
    The hole was drilled before turning. I left the ends on to provide support for the tapping. Probably not really necessary but the set screw sure went in nice with pre-cut threads.
ID:	56717 Click image for larger version.
    I didn't put any finish on because I wanted to test drive it for awhile and see if it was a keeper. I think I already like it.
ID:	56719 Click image for larger version.
    Cool idea, Glenn. How'd you cut cut the kerf? Did you do it before or after turning it?
    9,077
    Before. In Derek's version 1, he drilled a sequence of holes that matched the profile and chiseled them out. In version 2 he made a lamination with a piece of thin, shaped stock sandwiched in the thicker stock to make the blank. The piece of scrap I had was too small to take the loss of material to slice it up and re-glue it so, I went with version 1. I suggest version 2 to anyone else who might want to do this. Much more precise.
    12,264
    Very cool Glenn thanks for showing us the way. Maybe LV will pick up on this idea and offer it as an accessory
    How did it test drive for you?
    I have still got the making of a shooting board on my to do list along with dozens of other items. Some day.
    9,077
    LN already offers one for about $60 for their plane. If you know anyone with one of those . .. what-cha-ma-call-it spinny things, it really took less than an hour to go from blank to tote and I don't even know what I'm doing. I used it quite a bit last night and decided it was a keeper. The BLO is curing on it as I write this
    Aug 2008
    Reno, Nv
    3,632
    Being a little new to planes, what on earth is a hot dog tote for? I know what the tote/handle does...but this? I ran around the LN site for a bit and couldn't find one
    Sep 2007
    Plainwell, Michigan
    4,857
    Glenn is using it as an auxiliary tote for the side of the plane for using it on his shooting board. Glenn please correct me if I am not correct
    9,077
    Quote Originally Posted by Jim Burr View Post
    Tom is on the money. Gripping the plane body is more comfy on the LV LAJ than others I have tried but, the hot dog removes the fatigue if you have much trimming to do. It is common to use it with a Low Angle Jack and I see LN lists it on that page. Here's a pic of theirs from their website:
    Aug 2008
    Reno, Nv
    3,632
    Ahhh...got it. Looks like it would indeed come in handy.
    9,077
    Had a couple queries on the slot and how I made it. Again, Derek's site shows the process in better detail. I traced the profile of the plane side where the tote was to sit and cut it out to make a pattern. I then traced around the pattern on one side of the blank.
    Using the traced profile on the side of the blank I drilled a series of 13/64" overlapping holes of the appropriate depth to get me in the ball park. I then used an 1/8" chisel to get things close enough to work.
    I drilled the set screw hole, turned the blank but left the square ends on. Threaded the hole, cut the ends off sanded them smooth and hit it with BLO and shellac.
    Attached Thumbnails Attached Thumbnails hot dog slot-finish 006.jpg   hot dog slot-finish 008.jpg   hot dog slot-finish 009.jpg
  1. Beer Tote
    By Darren Wright in forum Flatwork Project Showcase
    Last Post: 02-24-2015, 07:41 PM
  2. Plane tote
    By Rob Keeble in forum Neander Tool Questions and Show & Tell
    Last Post: 07-31-2010, 01:07 AM
  3. The Ultimate Jack?
    By Derek Cohen in forum Neander Tool Questions and Show & Tell
    Last Post: 07-28-2009, 04:31 PM
  4. New playmate for Jack
    Last Post: 06-26-2009, 07:53 PM
  5. Next the Tote & Knob
    By Bart Leetch in forum Neander Tool Questions and Show & Tell
    Last Post: 04-17-2007, 12:37 PM
