Results 1 to 5 of 5
Thread: Finishing white oak
    Mar 2011
    Painesville Ohio
    131
    Finishing white oak
    I have a Coffee table and some end tables i need to finish. They want it to be clear no stain and coated with satin poly. What do i have to do to get it ready for poly? A grain filler? Or just sand and poly? Thanks for any help.
    Also will be brushing it on. Another note. Water based or solvent base?
    "Its only by minute attention to every detail that you will achieve perfection"
    May 2011
    Cape Cod, Ma.
    1,553
    Whether you decide to fill or not is determined by the final finish you are trying to achieve. If you are trying for a high gloss you don't have any choice but to fill. Also, with regards to waterborne finishes. Some of the waterbornes out there do not play nice with white oak. Check with the mfg before using them or you may be in for a dissapointment.
    You may consider using a good sanding sealer before coating (make sure it is compatible with urethane) This will help fill the pores somewhat and let you build your finish quicker. Also, may provide you with a sufficient barrier coat for a waterborne finish should you go that route. Most sanding sealers as with solvent based urethanes will give you an ambering effect as will some waterbornes (GF EnduroVar is one I use) but you can also get "water clear" or "ultra clear" in the waterborne finishes.
    General finishes puts out some very good products that will give you great results. Shoot them an email their customer service is very helpful.
    Also, you might email Jeff Jewitt at Homestead Finishing he has helped me out quite a bit in the past.
    Good luck
    Apr 2009
    Outside the beltway
    5,259
    I'll add that if you do fill apply a couple of coats of sealer 1st.
    ::: Andrew Wyeth :::
    colonialrestorationstudio.com
    Mar 2011
    Painesville Ohio
    131
    Thanks for the great replies. Going to go with a solvent-base poly satin. So if its not a high gloss finish i can just use poly with out sealer and filler? At least thats what i gathered from the above posts. Just slap me on the head if I read it wrong.
    And thanks again for the help.
    Apr 2009
    Outside the beltway
    5,259
    Their are 2 reasons to use use grain filler on the oak. One is Gloss as stated and 2 if you do not like the deep grain. Some I fill and some I don't, But its a quick fix with a good grain filler.
  1. Cynthia White
    By Brian McMillan in forum Designs, Plans and Sketches
    Last Post: 02-04-2016, 01:52 AM
  2. How to tell white Oak from Red Oak
    Last Post: 05-03-2015, 02:42 PM
  3. White and Red Oak
    By Lora Irish in forum General Woodworking Q&A
    Last Post: 03-26-2015, 12:29 PM
  4. White Oak burl jar
    Last Post: 10-01-2014, 10:42 AM
  5. Help! Need some White Oak
    By Bruce Shiverdecker in forum Old Ads
    Last Post: 09-14-2009, 11:49 AM
