Results 1 to 10 of 21
Thread: How do I cut a dowel in half?
    May 2009
    Lafayette, Indiana
    2,380
    How do I rip a 3/4" dowel rod in half. I'll have to use my band saw but I need some way to hold it with out it trying to turn. I'm thinking about drilling holes into two square blocks and glueing the dowel ends into those holes then run it through the saw. Is there a better way?
    11,833
    That would definitely be problematic. I have to ask: Why?
    OTOH, I had a similar dilemma with a recently completed project. I need half of a round object. What I did was saw a block in half, glued it back together then turned round but left the ends square. That way I could send it through the bandsaw and had a center line to follow. Worked out well.
    Or, you could cut your dowel a little long, bore a hole in a square hunk of wood, glue dowel in and bandsaw in half, cut to length needed.
    Independence, Kentucky
    1,355
    Tom what you described would work pretty well. If I were doing it I would take a piece of 2X4 and cut a shallow V groove into the wide side of the 2X and hot glue the dowel in the groove in a couple of places and then stand it on the edge and run it through the band saw using the fence to guide the cut.
    Chuck
    9,077
    Get a piece of 3/4" stock. Put a 3/8" radius roundover bit in your router table. Round one edge of the board, flip and round the other edge creating a half-round profile. Rip the half-round edge off on your tablesaw. Repeat.
    Dec 2008
    Santa Claus, In
    4,779
    I like Glenns idea. Make a bull nose and rip it off.
    11,833
    Quote Originally Posted by Steve Southwood View Post
    That would give him half a dowel. But, it doesn't answer the question of how to rip a dowel in half.
    1,355
    Go get em Frank!
    13,363
    Is it just me or am I the only one who finds the whole subject of ripping a dowel in half disturbing?
    1,355
    But sometimes you have to do what you have to do!
    Chuck
    May 2009
    Lafayette, Indiana
    2,380
    I do not have a table saw at this time so I'm going to have to do this with just my bandsaw. I need to end up with about 4" long pieces of "half round".
  1. Dowel Bit
    By John French in forum General Woodworking Q&A
    Last Post: 05-17-2012, 03:06 PM
  2. dowel pin maker
    Last Post: 07-14-2010, 04:12 PM
  3. half flat and half round
    Last Post: 12-06-2008, 11:55 PM
  4. Dowel pins
    By Jay Caughron in forum Old Ads
    Last Post: 11-17-2008, 09:28 PM
  5. Dowel Cutter
    By Mike Gabbay in forum General Woodworking Q&A
    Last Post: 02-08-2007, 01:21 AM
