Results 1 to 8 of 8
Thread: Which blade material type?
    Dec 2008
    Santa Claus, In
    4,779
    When buying new handplanes and the like, which blade material type should a person get? A2 or O1?
    This might have been covered before I can't remember.
    If it matters I use the scary sharp method for sharpening.
    5,322
    O-1 sharpens easier - particularly using sandpaper or stones (not diamonds)
    A-2, being harder, will wear stones (and you! ) out faster, and responds well to diamonds.
    A-2 will stay a little bit sharper a little bit longer.
    My personal preference is for O-1.
    Dec 2008
    Santa Claus, In
    4,779
    thanks Jim
    Villa Park, CA
    1,407
    I've been using A2 mostly and haven't had problems sharpening it on Shapton stones. The claim is that it holds an edge longer. I've never done a test to verify so I don't really know.
    Mike
    Ancora imparo
    Sep 2007
    St. Louis, MO
    583
    I use both - can't notice any practical difference either in use or sharpening. Maybe if i were working swirly grained exotic iron wood i could tell, but i'm pretty much a domestic hardwoods kind of guy.
    Either one is a dramitic improvement over the thin stock blades on most iron bench planes.
    Most of the blades on my planes are original Stanley issue and I don't know what those are, probably something like O1. I have a couple Hock O1 I like really well. Two planes, the Veritas snazzy little block plane and the Veritas medium shoulder plane, have A2 blades. They're a little more difficult to sharpen on my crappy King stones but they take a really good edge (as good as O1) and I think last a little longer.
    I'm switching to diamonds and sharpening just won't be a factor anymore.
    Both A2 and O1 respond well to regular stropping, as do my chisels (Berg, Hirsch and Matsumura white steel).
    Mar 2010
    Decatur, Alabama
    518
    I use mostly A2, so not a lot of personal experience with O1. A2 is a little harder material, so it will last little longer/harder to sharpen. The selling point I've heard for O1 was that it really excelled at angles below 25 degrees because of the ease of sharpening. A2 might be a little brittle for that low of an angle? I only have bevel up planes and regular bench chisels, so don't have any tools I sharpen lower than 25, haven't got to test it out yet.
    Dec 2008
    Santa Claus, In
    4,779
    Thanks for the info all. I went with the O-1
  1. Looking for non-skid material
    By Matt Ducar in forum General Woodworking Q&A
    Last Post: 12-11-2011, 02:04 AM
  2. Optimum Blade Type For Milling Cove Molding On A TS
    By Keith Starosta in forum General Woodworking Q&A
    Last Post: 05-07-2008, 02:13 AM
  3. vise jaw material
    By Mark Kosmowski in forum Neander Tool Questions and Show & Tell
    Last Post: 10-21-2007, 04:39 PM
  4. As The Saw Blade Turns (updated blade charts)
    By scott spencer in forum New Tools
    Last Post: 07-18-2007, 06:05 PM
  5. Material for drawers?
    Last Post: 04-12-2007, 02:11 AM
