Results 1 to 10 of 17
Thread: Cedar Arbor.
    Woodstock, Ontario, Canada
    719
    Cedar Arbor.
    Our budget metal arbor rusted away where it meets the sidewalk. Having some cedar cull hanging around the shop for 4 years, thought I could find a free plan that would work.
ID:	56935Popular Mechanics plan! nice! and it's free!
ID:	56936 Glued up overlapping 20" segments of 2x6 cedar, cut 22.5 degrees
ID:	56937slider made trimming the ends square easy, at 46" wide the arbor just makes it through the blade
ID:	56939nailing on the lattice pcs
ID:	56940I bought 10 ft cedar 4x4 posts, longest I could find at lumber yards, making each one 60", 2" short of the plan . I will reduce the cross lattice pieces spacing by a 1/4" so they don't over run the post length.
ID:	56942test fit, but have concerns arbor may be too narrow for it's location
    I'm thinking of making new arches, 57" wide, 50" inside width, in an oval shape. Arbor needs to be wide enough for two people to pass side by side ( Wife's elderly customers need assistance). The current inside width of 40" is a bit tight.
    hobby woodworking since 1972
    10,604
    Very nice Bryan
    Lake City, Florida
    498
    Bryan, have you considered cutting a piece from the center of the arches and adding a longer section?
    You can simply cut the arch in half vertically and add a straight 17" section
    --- or ---
    cut it horizontally taking the top section off, add in a new wider top section and recreate a new arch (hope that makes sense, hard to explain without a sketch)
    Tony, BCE '75
    719
    Quote Originally Posted by Tony Falotico View Post
    --- or ---
    I have thought of that too, but a wider arch is in the works, have it drawn on the bench using the oval string method, just need the time to cut pieces and glue them up! Saturday's shop time! I may have to build another set of the legs! So I can use up the arch!
    North West Indiana
    6,098
    Wife's customers??? Hey, set that new one out for sale!
    That is a top notch job!
    Could you tell me more about the lower shelf/tray (where the glue bottle seems to be) on the front of your workbench? Does it have a specific function? I am afraid in my shop it would collect clutter.
    Jon
    719
    Quote Originally Posted by Jonathan Shively View Post
    what you are seeing as my
    workbench is actually a stroke sander. Electric lift 3x8 table is so handy! see avatar
    North West Indiana
    6,098
    My trifocals are having a hard time distinguishing specifics on your avatar!
    Did you ever have a thread about this sander?
    Jon
    11,828
    You are obviously not a stranger in your well equiped shop.
    You did a beautiful job on the arbor, I'm sure your wife loves and appreciates.
    When the metal one I bought years ago for my wife started showing rust I took the lazy, but expensive, way out. I had it sand blasted and powder coated. Hopefully, it will now last longer than us.
    new york city burbs
    10,188
    nice product bryan,
    how is it working with white cedar, dust?
    I was thinking about using some decking white cedar to make a few chairs.
    Do you put anything like thompsons on that, spar urethane? or just leave it?
    That is a looker. Very inspiring. What did you choose for your glue?
  1. TS Arbor Nut
    By Alex Reid in forum General Woodworking Q&A
    Last Post: 04-12-2011, 11:52 PM
  2. How to lock chuck onto arbor?
    By Jerry Ingraham in forum Turning Tool Questions and Show & Tell
    Last Post: 02-14-2009, 03:54 PM
  3. Rustic Arbor
    By john looser in forum Flatwork Project Showcase
    Last Post: 08-06-2008, 12:26 PM
  4. Arbor Installed - Finally
    By Wes Bischel in forum Flatwork Project Showcase
    Last Post: 07-23-2008, 08:10 PM
  5. Tablesaw arbor nut comes loose and I know why
    By Travis Porter in forum General Woodworking Q&A
    Last Post: 02-15-2007, 05:36 PM
