Results 1 to 10 of 10
Thread: Recommended Table Top Finish
    13,448
    My wife's uncle is wanting a recommendation for a table top finish. He used a lacquer finish on a table and he says that anything warm sticks to the table top. I recommended using trivets but he said those stuck as well.
    Is there another type of finish he can put on the table that will be more heat resistant (warm, not hot dishes) and that objects wont stick to? Or would waxing the top or something like that help?
    Thanks...
    5,321
    I've used Behlen's "Rock Hard" and also General Finish's "Arm-R-Seal" on dining table tops with good results.
    The Arm-R-Seal is a lot easier to use, but for durability I'd lean more towards the Rock Hard.
    The Rock Hard definitely lives up to its name when it comes time to rub it out, though. It's what's on my current DR table, and it's been on there for about 12, maybe even 15, years and is just now starting to show some signs of wear. We don't use tablecloths, but do generally use placemats and trivets, so the finish certainly hasn't been 'babied' over the years.
    4,552
    The table company's around here use catalyzed Lacquer and it seems to hold up well. Check with someone like Sherwin-Williams.
    A Turn N Time
    Frog Pond Guitars
    Apr 2009
    Outside the beltway
    5,255
    Quote Originally Posted by Jay Caughron View Post
    A Pre Cat Lacquer will do much better on top then the nitrocellulose. But with any product you can not use a hot medal trivet on any top except a bar top finished top.
    ::: Andrew Wyeth :::
    colonialrestorationstudio.com
    13,448
    Thanks all!
    Aug 2008
    Reno, Nv
    3,632
    My BIL uses Catalized Lacquer on all his table tops...my coffee table top he made for us has held up for 6-8 years with only minor wear.
    Jan 2011
    Plas Llwyngwern, Machynlleth, Wales
    46
    So... one caveat... I know noooothing - I'm just repeating what I heard the man in WS Jenkins say, when askling him about lacquers for my furniture...
    All of these lacquers use nitrocellulose solvent.
    There is pre-catalysed lacquer, which has the catalyst already inside, this is the least durable. The bar top lacquer is a bit more durable to alcohol and moisture - but the most durable is "acid cat" which I am sure is what you mean by catalysed lacquer (not a moggie that has been fed LSD I'm guessing).
    The acid cat goes off more quickly when it is mixed, is slightly more expensive, and an additional step in the prep.
    And... I am told to thin all of the lacquers by 10% with thinners.
    Apr 2009
    Outside the beltway
    5,255
    gavin I use one of the top lacquer on the market, never heard of acid lacquer but I know that Mag-Na Max ML Cambles is the best and the hardest of all Lacquers, comparable to a conversion varnish. As far as bar top finishes that where they belong on bar tops.
    Conversion varnishes are a different monster, they are harder then granite and have a very distinct look, Plastic. So people get a charge out of that look but the majority of my customers would not call me back if I use a conversion varnish.
    Mar 2010
    Decatur, Alabama
    518
    Sounds like post-cat lacquer? I think the catalysts are acids.
    Apr 2009
    Outside the beltway
    5,255
    Jeb I use all Pre-cat.
  1. Recommended Spray Adhesive?
    By David Agnew in forum General Woodworking Q&A
    Last Post: 01-25-2015, 05:06 AM
  2. Recommended lathe height
    By Rob Keeble in forum General Woodturning Q&A
    Last Post: 01-07-2013, 05:16 AM
  3. TABLE TOP FINISH
    By Sayer Fancher in forum Finishing School
    Last Post: 01-05-2013, 05:50 PM
  4. What is Your Favorite Table Top Finish?
    By Tony Bilello in forum Finishing School
    Last Post: 12-28-2009, 01:01 PM
  5. table top finish
    By Mark Kosmowski in forum Finishing School
    Last Post: 06-06-2009, 01:53 PM
