Results 1 to 10 of 14
Thread: How to unclog a pond overflow pipe?
    Jul 2007
    DSM, IA
    5,719
    My MIL's cabin has a very small pond down the hill from it and the overflow pipe is clogged, probably at the intake. Any ideas other than getting the swimsuit out and mucking it out by hand?
    Power outlet on the cabin is over 200ft away and getting a plumber out there to "roto root" it out would be way to pricy because it is pretty remote, no water at the cabin either, so I can't blow it out with water.
    My Website
    North West Indiana
    6,097
    I'm thinking boat, large corkscrew type device if a piece of pipe can't be driven through. All else fails, one stick of dynamite ought to do it!!
    Jon
    13,357
    Quote Originally Posted by Jonathan Shively View Post
    +1 on the dynamite, just make sure to video the whole process...
    Snake it
    "Thereís a lot of work being done today that doesnít have any soul in it. The technique may be the utmost perfection, yet it is lifeless. It doesnít have a soul. I hope my furniture has a soul to it." - Sam Maloof
    Jan 2011
    3,798
    I'd try a portable compressor, generator and 100' of air line
    Dec 2008
    Santa Claus, In
    4,779
    If you are in the water when you unstop it, be careful of the suction pressure once it frees up. The higher level over the pipe the worse it will be. You probably already knew this but being reminded is better than the alternative.
    Jul 2007
    DSM, IA
    5,719
    Steve, I have thought about the suction pressure if I get it unclogged. My MIL said she didn't want me to try it this way because of that, but the water should only be waste high...getting my foot/leg stuck in the mud will probably be a bigger concern. DAMHIKT.
    I don't have access to dynamite, but that would be worthy of a video for sure!
    I was told by someone here at work to take a 20ft section of 6-8" flexible drain pipe, put one end in a 5 gallon bucket and fill it with water, then stick the other end in the pond, take the bucket off and you can drain quite a bit of water pretty fast...might give that a go too so we can get to the drain easier...I also read some terrilbe accounts of what people have found in a clogged pond pipe.
    My Website
    11,825
    What is diameter and length of the pipe?
    Mebbe just shove something in from the 'out' side.
    Jul 2007
    DSM, IA
    5,719
    The pipe is 6" I think...I will be taking a 8ft 1" pipe with me to shove into the pipe from the dry side...that should be long enough. Problem is I haven't really ever looked that close at it so I'm planning all this kinda blind...
    My Website
    Buse Township MN
    565
    I've unclogged lots of water control structures. Corn rakes, long handle hoe, capped pipe to "probe" as you mentioned, and backhoe's. Good luck!
    Every child deserves a family. Adopt. Foster. Get involved.
  1. My Brand New Frog Pond Guitar!
    By Brent Dowell in forum Flatwork Project Showcase
    Last Post: 05-17-2013, 10:24 PM
  2. pipe for pipe clamps
    Last Post: 11-03-2012, 12:09 AM
  3. A new wood for you guys over the pond.
    Last Post: 02-22-2012, 11:48 PM
  4. New Sharpening Pond and Stone Holders
    By Bill Satko in forum Jigs and Fixtures
    Last Post: 12-08-2009, 03:29 PM
  5. Moving across the pond...
    By Greg Cook in forum Off Topic Discussion
    Last Post: 06-23-2007, 05:01 AM
