Results 1 to 9 of 9
Thread: Light pull question
    Light pull question
    I want to make up a couple of light pulls for my next show. I don't want to buy the kits that they have. My question is how do you make one with out there being a hole that shows from the bottom. The kits have a plug that they use. Also if there has to be a whole what do you use so that it's not so large as the one I left behind? I used the niles stopper mandrel.
    Dennis
Name:	100_0927 (600 x 450).jpg
Name:	100_0928 (600 x 450).jpg
    North West Indiana
    6,098
    What about turning a dowel that fits in the threaded end, then drill the dowel for the chain and glue it in. Thus the other end doesn't have a hole, problem solved?
    Jon
    Aug 2008
    Reno, Nv
    3,632
    I think it's an m47 tap you can thread the end of a brass tube with and screw the fitting into. Or you could drill up to 1/4" of the end with a 3/8" bit the down the last 1/4" with a 3/32" for the chain exit and knot the chain in the bigger side and forget the fitting.
    11,832
    I can think of several ways to turn it without a bottom hole.
    But, I'm wondering how the chain would be fixed to the pull without a bottom hole.
    North West Indiana
    6,098
    Doesn't need bottom hole, the chain comes from the top towards the ceiling fan.
    Jon
    Tellico Plains, Tennessee
    4,352
    Quote Originally Posted by Jonathan Shively View Post
    But you would need to epoxy the chain in... if you have a bottom hole, you can drill a hole at the top just large enough for the chain to pass through, but a larger ball on the bottom of the chain, or a small washer to catch in the smaller hole... then either plug the bottom hole or a couple of drops of epoxy there.
    Chuck
    Tellico Plains, TN
    Aug 2008
    Reno, Nv
    3,632
    Or you could do one in 2 pieces and hide the bottom of the chain all together
    11,832
    Yep, wat I wuz thinkin' too. Hafta be epoxy to hold in. But, if chain ever needs replacing, and it happens, whole, nice pretty turned, knob might have to be tossed.
    Orem, Utah
    935
    I like Jim's idea of using threading in some way.
    • You could turn a "hollow tenon" on the upper end, and screw on a cap of some kind.
    • You could drill a smaller hole in the end and screw in a cap of some kind.
    Either way, you could make the hole in the cap large enough the pass the chain / string, but small enough to prevent the ball or knot on the end.
  1. Light Colored Wood Paneling Question
    By Scott R Smith in forum Finishing School
    Last Post: 01-03-2015, 01:58 AM
  2. Workshop light for lathe question
    Last Post: 07-03-2013, 09:57 PM
  3. Pull!
    By Ned Bulken in forum New Tools
    Last Post: 09-01-2009, 10:41 AM
  4. Pull saw . . .
    By steve mackay in forum Neander Woodworking Q&A
    Last Post: 11-23-2007, 07:17 AM
  5. Elec. Question - Wiring DC Bin Level Sensor to Alarm Light
    By Doug Shepard in forum General Woodworking Q&A
    Last Post: 11-24-2006, 03:59 PM
