Results 1 to 9 of 9
Thread: Sandblast units
    Oct 2008
    Upstate S.C. near Anderson
    26
    Sandblast units
    Thinking about a Northern Tools sandblast cabinet. I also have located a USA made portable unit that holds 75 lbs. Has anyone used a portable unit? Can you reuse the blast medium? Do you set up a tent to do the blasting, and how do you reclaim the sand/medium? If you had a choice, would you buy both? Any good source for a used cabinet unit? I live in upstate S.C. Thanks!
    Jim Evatt
    Jim I have a habor freight unit. Link It is very messy and I use it out doors, put down a drop cloth and reclaim as much material as I can it works as advertised but I also only sand blast when I need to., Did I say it was messy.
    North West Indiana
    6,098
    Also get the hood. Want to talk about toxic dust, sandblasting dust is a real killer.
    Jon
    Oct 2008
    26
    Thnks replies.
    I am going to look at procedure for open sandblasting under a tent wearing a good respirator. I guess you would just scoop up the spent medium and reuse it, it would be contaminated and might clog it up,any thoughts on this, Northern Tools seems to have the best price on an inexpensive unit. There's is the only one that shows top-loading in addition to side loads. Any ideas?
    Jim Evatt
    North West Indiana
    6,098
    My old Sears gravity sandblaster had a screen to run the reused material through. No more than I used it, I found it cheaper and easier to buy new material, less fuss. Black beauty was a good sharp sand.
    Jon
    Aug 2008
    Reno, Nv
    3,632
    Quote Originally Posted by Jonathan Shively View Post
    Thanks for being safe Jon! Most blast medium is silicate...A leading cause of Pulmonary Fibrosis. The only known cure is a lung transplant. I've used the HF tank a few years ago. Works well and to add exclamation...it's messy! And yes...I used a hood and my respirator!
    Southeast Pa
    2,019
    how about the soda units? All hype or what?
    3,134
    I think I purchased the 20# HF unit & used it to blast the plinth & hand wheels & case as well as the inside of my Unisaw. I didn't buy blasting sand I just purchased some 50# bags of play sand & it did just fine.
    NH
    4,005
    Did anyone tell ya it's kinda messy???????????
    I tried to reuse the sand just one time. I learned real fast that once it leaves the nozzle it is gone forget about it.
    Stupid hurts.
  1. Movable shelving units
    Last Post: 08-12-2012, 12:52 PM
  2. Dimension units?
    By Jeff Horton in forum Designs, Plans and Sketches
    Last Post: 03-05-2007, 11:13 AM
