Results 1 to 4 of 4
Thread: Collar and Finial - wood movement
    Palm Springs, Ca
    1,169
    I just finished reading thru Lyle Jamison's newsletter about how to work with a collars on the opening of a vessel and then adding a finial on the top of that. I agree with his comment that Cindy Drozda is a master at the finial stuff.
    Anyway, regarding how to approach collars and finials he suggested:
    First option was to rough out and let dry and then return it to keep the opening from warping or distorting - like he said there are difficulties in working with dried out wood..... not my choice nor what I do either
    Second was finish the entire vessel and go back and true up the opening when dry. You can then create a ledge also after truing up the opening.......... To me------that does not seem to be a very good method because you could easily mess up the opening. Or if it warps upward on you then there may not be enough wood/stability to trim down again to get rid of the distortion. I suppose you could leave the rim area a bit thicker to take some of the second cutting into consideration............
    Third was to cut to final thickness and let dry then cut the collar a bit larger in diameter to hide the distortion in the opening but this does not account for upward warping on the top of the vessel unless you turned it thick on the top to give yourself extra material for a second returning of the top portion.
    I try alot of different approaches (including the above 2nd and 3rd)to keeping the opening true as possible......I have sprayed some MS on the rim and used my compressed air nozzle to spray it into the wood-like blowing it into the pores to displace any moisture in there....and then using
    CA on the rim inside and out about 1/2" and it works with some woods.
    Anybody else game to suggest other ways ????
    The few collars I've turned were done on dried wood, and placed on hollow forms that were twice-turned, with the final fitting of the collar happening after the vessel was dried and re-trued. Re-truing around the opening is indeed a bit risky, but hey...if it was easy everyone would wanna do it.
    Goodland, Kansas
    4,834
    I do the same. I either rough turn and then let dry. Once dry I return to finish turning then add the collar. It definitely can be risky but hey is anything easy? Once the collar is in place and true I turn the finial from kiln dried wood. The wood must be dry for sure or you will have problems.
    Bernie W.
    Palm Springs, Ca
    1,169
    I use dried wood to on finials and collars but I have turned both collars and finials wet and set them to the side to dry. If I turned them wet i turn the shape to finish, wet sanding etc and leave the base diameter a bit oversize to allow for any shrinking. I then set to the side to dry - they all have tennons at this point so i can put back in the chuck for 0000 and more finish or to take down the last little bit to final diameter and part off.
    I actually have a collection of Finials that i just made messing around that i use this approach on and it works well for me to control diameter and drying time is speeded up.
  1. wood movement
    By Roger Pozzi in forum General Woodworking Q&A
    Last Post: 12-13-2014, 04:16 PM
  2. Wood Movement
    By Chas Jones in forum General Woodturning Q&A
    Last Post: 01-30-2012, 08:32 PM
  3. Wood Movement
    Last Post: 12-27-2010, 04:02 PM
  4. how common is wood movement really?
    Last Post: 02-13-2008, 03:01 PM
  5. wood movement
    By Gene Miller in forum General Woodworking Q&A
    Last Post: 09-24-2007, 11:01 PM
