Results 1 to 7 of 7
Thread: Finials and New Trial of EEE/Shellawax
    Palm Springs, Ca
    1,169
    Awhile back I purchased some EEE and Shellawax but I had not tried it until the other day. Reason was there is a turner Ian Robertson (in England I believe). He has written a protocol for using the two products and you can find it on AAW. Anyway, I took a scrap pc of wood and turned a small finial fairly quick for the vessel in the picture. I sanded to 1000 grit.
    I turned the lathe up to 1500rpms and applied the EEE with a pc of old T-shirt and pushed hard and rubbed it in back and forth several times. Then changed to a clean pc of T-shirt and rubbed hard again to clean it.
    Then using the Shellawax paste I applied it the same way as above. Let dry for 45min give or take and using a small pc of lambs wool rubbed it one final time.
    Note: The Vessel was finished with Waterlox 3 coats and knocked down and buffed awhile ago.
    I read you can use some liquid shellawax and thin down the paste for large projects. I have not tried that yet but this is the 3rd Finial I have used Shellawax on and if you apply it right I think it works great.......
    I was not able to upload the tutorial for everyone - says file size is to large............ill try to figure out a way but until then for anyone interested
    http://www.ubeaut.com.au/swinfo.htm <----------Shellawax website with more information.
    30,019
    That's good info on the Shellawax website. They not only tell how to use it, but why.
    If you want, e-mail the PDF file to webmaster - at - familywoodworking.org and one of us Admins can upload it manually.
    Palm Springs, Ca
    1,169
    Vaughn.............I sent it and asked if someone could put it on this post.......I think this would be a very interesting thing for anyone that may want to try it or that has had problems using it...............thanks Dan
    Goodland, Kansas
    4,834
    Good looking piece Dan. I use the EEE and Shellwax. Shellwax doesn't hold up as nicely as I would like but the EEE works really nicely.
    Bernie W.
    30,019
    Dan, I've converted the .doc file you sent into a .pdf file. It's available here:
    Ian Robertson Shellawax Tutorial
    Oct 2010
    Abq, NM
    312
    Nice piece and +1 for EEE - no wax beyond that here. Thanks for upping the intel, I'll review it.
    mj
    Palm Springs, Ca
    1,169
    The tutorial is up thanks to Vaughn........I will say that if you follow Ian's protocol for using EEE and shellawax you will not be disappointed.
    From the letter he sent me the mistake turners usually make is that they use to much when you only need a small dab, or they apply it wrong and get so so results.............I followed the tutorial and have been happy with the results.............
  1. Shellawax Cream
    By Cynthia White in forum Finishing School
    Last Post: 12-09-2014, 01:00 AM
  2. Reproduction Finials
    By Matt Hutchinson in forum Lathe Project Showcase
    Last Post: 02-22-2013, 10:02 PM
  3. Small Walnut vessel - Shellawax finish
    By Dan Mosley in forum Lathe Project Showcase
    Last Post: 06-29-2011, 09:43 PM
  4. A couple more with twisted finials
    By Richard Madden in forum Lathe Project Showcase
    Last Post: 04-01-2011, 02:24 PM
  5. Hollowing and Finials - what I learned
    Last Post: 02-01-2010, 05:13 AM
