Results 1 to 10 of 12
Thread: pergola anyone?
    May 2011
    edmonton alberta canada
    6
    pergola anyone?
    ok i guess this would be my frist post here and i have to start somewhere soooo... my backyard deck is 23ft x 16ft and the wife says she wants a pergola above it. I will need 3 or 4 beams 23-24 ft long to span the lenght, there is no option of spanning the other direction and no chance i will put support post in the middle of my deck. does anybody here have and experience making their own glue lam beams? i was thinking 4-6x 3/4 by 7 1/2 inch strips of plywood glued, then encasing it in cedar with some west system 2 part epoxy. am i way off base here or do i get a second and third mortgage on the place and just order 4 solid cedar beams?
    Dec 2008
    Santa Claus, In
    4,779
    Might work, but I think I would bolt them together also. Just to be on the safe side. Recess the head and nut, then cover it with the cedar. I would even go as far as just to use 2x10's or something. That is the way basement beams used to be done. Long as you could keep the water out of it, I really don't see a problem.
    Oh and welcome.
    May 2011
    6
    thanks steve i thought about solid wood 2x8 or 2x10 but came to think that plywood is way more structurally stable and if im not mistaken a beam made of plywood 7 1/2 inches by 4 1/2 inches (6 layers thick x 3/4 inch) should be darn close to tank proof? idk just a thought
    Dec 2008
    Santa Claus, In
    4,779
    Well you also need to think about snow loads up there, where I really don't have to here. Hopefully one of the northern guys will see this and chime in.
    Floydada, Tx
    1,941
    Glue lam beams are not meant for outdoor use. Youy are going to need on heck of a chunk of timber to spaned over 20'. I dont think I would even try to spand that with out getting someone with exp in support loads.
    May 2011
    6
    the beam will be in a totally weather/waterproof enclosure, the west system epoxy is the same stuff that the wood boat builders use and the weightload is not much 40 or so 2x8x16 cedar planks on their edge so no snow load or waterload just their weight i could even put fiberglass matt under the epoxy but i really dont think that it would need it
    North West Indiana
    6,099
    I would tend to agree here with Al, delamination due to moisture/humidity would be your big enemy. You don't need a post directly in the center, but a pair of posts with a beam spanning their top for the long beams to lay crosswise onto would help. (clear as mud???) Pergolas don't really hold much of a snow load as they aren't a solid roof, only slatted for shade correct? What about a gazebo over half of the deck?
    By the way, welcome to the family!!
    Jon
    May 2011
    6
    that is the plan just a slatted roof. You think that delam would be a problem even if its totally encased in a fiberglass resin without the cloth? I would much rather see the cedar than the fiberglass mesh so i would skip the cloth
    North West Indiana
    6,099
    Yes, I think delamination would happen eventually. Snow and ice sitting on top of the beams, a warm day, wet puddles, freezing cold night causing a crack to develop, water seepage, a couple of days later warm again, laminated beam soaking up water through the crack in the fiberglass, freezing night again, delamination occurring. Might be years before you realize it, but don't think I would take the chance. Around here many of the old electric poles were cedar. If you could get a sawyer to square up a cedar telephone/electric poles for you then you would be in business.
    Jon
    May 2011
    6
    there is an idea sure but here they are all tamarac poles hmmm
  1. The Pergola Is Up
    By scott spencer in forum Carpentry and Construction
    Last Post: 08-29-2011, 07:34 PM
  2. pergola for al k
    By Dan Noren in forum Designs, Plans and Sketches
    Last Post: 08-19-2009, 08:35 PM
  3. A few projects to catch up on................#5 HUGE pergola
    By Mark Rios in forum Carpentry and Construction
    Last Post: 06-06-2007, 12:46 AM
Tags for this Thread
