Results 1 to 7 of 7
Thread: 12 sided Bucket
    Sep 2007
    Bloomington MN USA
    268
    12 sided Bucket
    I had a piece of redwood fence that I have been hanging onto forever. About 40 years or so. Had a few knots but pretty straight grain. I had also just made a tappering jig that I was dieing to try out,other than making a couple of sample cutts. So after cleaning up the redwood fence board and cutting out the pieces to size I at last had my chance to try out the tappering jig. It works great and was the easiest part of the project. The tuff part was trying to glue all of those tapered pieces together and get the bottom to fit into the grooves at the bottom of the bucket.
Name:	Redwood Bucket.JPG
    It turned out OK but am thinking about either putting a top on it or making a handle for it.
    The tappering Jig was one I saw on line and it looked like a good project to do. Just don't know how often I will use it. The hold downs were a little tuff bending but the are working very well as do the cams that hold the work piece. I also made the stop block ajustable with extra holes.
    I know part of the thread belongs in Jigs and Fixtures but the bucket got lonsome.
    If you make a mistake it was part of the original plan!
    new york city burbs
    10,188
    that is one fancy tapering jig.
    My tapering jig is just a piece of melamine, and 2 sticks to hold the angle.
    I slide it through the taper cut and slide it back if its a small taper, otherwise the end of the leg is far enough from the blade I hold it down when running to the other side.
    I made a 6 sided bucket a while back, not tapered, but I used clear packing tape, laid the pieces on the table flat on top of tape, then glued, and taped it closed in two spots and it held great.
    It was a planter I made out of pressure treated.
    Jan 2011
    3,798
    Nice job & cool jig ...I'm picturing a hammered wrought iron handle...FWIW
    10,600
    the bucket is great I can imagine how hard it was to get every part aligned for gluing
    Nice jig too
    May 2011
    Cape Cod, Ma.
    1,553
    Nice work, Challenging little project getting the bevel and angle just right so the last piece meets up with the first piece!
    30,008
    Great-looking jig, Ron.
    13,437
    That's a great looking jig The bucket is missing the works for the part that makes ice cream though.
  1. one more off the bucket list
    By Chuck Ellis in forum Lathe Project Showcase
    Last Post: 03-31-2016, 02:52 AM
  2. Another Bucket List Item
    By Paul Douglass in forum Flatwork Project Showcase
    Last Post: 05-21-2013, 01:55 PM
  3. What's on your bucket list?
    By John Daugherty in forum Off Topic Discussion
    Last Post: 12-02-2011, 10:05 PM
  4. The Ice Bucket
    By Dennis Kranz in forum Lathe Project Showcase
    Last Post: 09-16-2011, 07:51 AM
  5. Bucket Case Bandsaw
    By Jeff Horton in forum Old Iron
    Last Post: 07-16-2007, 02:42 PM
