Results 1 to 6 of 6
Thread: Back to my hollowing tool rig.
    May 2009
    Lafayette, Indiana
    2,380
    Earlier this spring I welded up a hollowing rig system but never got around to making any boring bars for it. I have plenty of 3/4" stainless steel rod for the bars and have been looking on E-bay for some bits. Does it matter if the bits are (HSS) or cobalt or carbide. If we are only cutting wood will any of them work? Also some of the bits were made for only right hand or left hand cutting. For our use will I be reshaping the bits anyway?
    I bought a small 1/4" square set at Harbor Freight that had 5 bits in it. (2 right, 2 left and a pointed bit). Does anyone have good close photos of what they are using for bits?
    Jul 2007
    DSM, IA
    5,719
    Tom, I've used the Harbor frieght cutters for over 3yrs...they're cheap so you can experiement with grinds and such.
    Vaughn also did a tutorial on his bars and bits click here
    My Website
    HSS is fine. The 5% or 10% cobalt bits are more heat resistant, but that's really only a benefit when used for cutting metal. Carbide bits are a whole other animal. There are a variety of carbide bits out there, but not all of them are suitable for woodturning. And they're not something you can sharpen yourself.
    I sharpen my bits at the same angle I use for my scrapers. Here are a few pics of a large bit. I do small ones the same way. The grinding causes a burr to be created on the leading edge of the bit. The burr is what's doing the cutting.
Name:	Hollowing Cutter Setup 03 - 600.jpg
Name:	Hollowing Cutter Setup 04 - 600.jpg
Name:	Hollowing Cutter Setup 05 - 600.jpg
Name:	Hollowing Cutter Setup 06 - 600.jpg
Name:	Hollowing Cutter Setup 02 - 600.jpg
    When used in a hollowing rig, I like to set things up so the cutting edge is hitting at exactly the centerline of the piece...
Name:	Hollowing Cutter Setup 01 Annotated - 600.jpg
    May 2009
    Lafayette, Indiana
    2,380
    Jeff thanks for the link. Actually I had saved that before but you brought it back to my attention.
    Vaughn...you must have photos of everything. That's great because they help me alot. Thank you.
    Aug 2008
    Reno, Nv
    3,632
    Hmmm...gonna have to give that a try
    12,264
    Jim thats just what i was thinking. Oh boy now i know why its bad for a guy like me to follow some posts here. Dang now my list of non completed half started projects is gonna catch up to mmmmm a guy in Nevada.
  1. Want a Hollowing Tool
    By Mike Turner in forum General Woodturning Q&A
    Last Post: 12-18-2014, 11:46 PM
  2. Captive Hollowing Tool Bar ?
    Last Post: 11-18-2012, 02:48 AM
  3. Hollowing rig back up and running & D-arm work
    By Dan Mosley in forum Lathe Project Showcase
    Last Post: 09-20-2010, 02:43 AM
  4. Laser for Hollowing tool
    By Wayne Bower in forum Turning Tool Questions and Show & Tell
    Last Post: 06-10-2008, 04:06 PM
  5. **SOLD** Pro-Forme Tool Hollowing Tool Set
    By David Propst in forum Old Ads
    Last Post: 03-30-2008, 03:08 PM
