Results 1 to 6 of 6
Thread: Recovering brick fireplace with wood
    We have an enormous brick fireplace we'd like to cover in wood like the image attached. I know there are many opinions about the best way to attach wood to brick, so I'm curious what you would do? Also, does anyone foresee problems I'm probably overlooking? Like is it a fire code violation?
    13,464
    Darcie, Welcome to the family!
    One of our other members recently did a wood overlay...see here: http://familywoodworking.org/forums/...replace&page=2
    You might check with your local codes to see how close the wood can be to the opening without creating a fire hazard. Seems like around 12" from the top of the opening, can be less on the sides, but don't remember the specifics.
    10,604
    Sounds like a job for Rennie
    Welcome Darcie !!!
    Thanks! I had seen Rennie's project but wondered if simply adding wood that doesn't have to support anything could be less invasive. But I suppose if you can hang a mantel that way, that should be good enough for thin boards.
    I was thinking vertical furring strips secured with masonry screws would be the base and then give me something to secure my wood to. But since the brick is an uneven pattern, I'm wondering if framing the entire fireplace in particle board would give me an even (and strong enough) surface to attach my reclaimed wood?
    Darcie, I think OSB (oriented strand board) would be a much better backing than particle board. I'll let some of the other guys with more carpentry experience chime in on the furring strips vs. solid backing question.
  1. Another Old Brick Stand
    By Dave Hoskins in forum Turning Tool Questions and Show & Tell
    Last Post: 11-08-2015, 01:23 PM
  2. securing pt 2x4's to a brick wall
    By Daniel Edney in forum General Woodworking Q&A
    Last Post: 09-08-2013, 12:13 PM
  3. Opinions needed - refacing brick fireplace
    By John Hemenway in forum Carpentry and Construction
    Last Post: 04-09-2012, 03:36 PM
  4. Attaching wood to brick - Nix the Tapcons
    By Rennie Heuer in forum Carpentry and Construction
    Last Post: 10-21-2010, 02:13 AM
  5. Brick stoop - sort of
    By Matt Warfield in forum Carpentry and Construction
    Last Post: 08-03-2007, 07:01 PM
Tags for this Thread
