Results 1 to 10 of 17
Thread: Milk paint
    Dec 2008
    Santa Claus, In
    4,779
    Milk paint
    Question about milk paint.
    Can milk paint be painted over? Nothing special about it, is there?
    Apr 2009
    Outside the beltway
    5,255
    YES. But try to strip it ...........good luck to ya.
    ::: Andrew Wyeth :::
    colonialrestorationstudio.com
    Jan 2011
    3,798
    Snagged from DIY Help .com....Hope it helps
    "Milk paint, also called casein paint, is sometimes found in older houses on walls or as a finish on antique furniture. As the name implies this paint was made using milk as the vehicle. It has a hard finish and is impervious to paint strippers. You can spot casein paint by its very smooth finish and pale, pastel colors including: yellow, pink, blue and green.
    If you have milk paint on your walls it will probably be a problem to paint or decorate with wallpaper because it doesn't hold a conventional paint finish well. Before you repaint over milk paint use a primerĖsealer to seal it and you will greatly improve your chances of success."
    Jan 2011
    3,798
    Some more info concerning stripping milk paint...FWIW
    see the 'unstrippable finish' article...
    http://books.google.com/books?id=QGt...0paint&f=false
    Dec 2008
    Santa Claus, In
    4,779
    I should mention, this will be new cabinet with a milk paint finish. Later it might get repainted.
    Apr 2009
    Outside the beltway
    5,255
    Why , what possessed you to use Milk paint that is nothing but a beast that will cause you problems down the road. If you do use it you will remember I told you so
    Dec 2008
    Santa Claus, In
    4,779
    Quote Originally Posted by Dave Hawksford View Post
    Thanks Dad It is not on yet. I wanted to check some things out first. Just like you taught me, Dad
    So basically, the new stuff is just as bad as the old stuff?
    Apr 2009
    Outside the beltway
    5,255
    ya son it is LOL If I were to use milk on anything it would be in a hunting cabin or something like that, most people who use milk paint are craft person's doing small wood crafts.
    Dec 2008
    Santa Claus, In
    4,779
    Thanks, I guess I will just look for a black that is close to the milk black.
    Apr 2009
    Outside the beltway
    5,255
    I can tell ya how to get the black closer by tinting useing a little red to make it warmer or blue to make it cooler, warmer is towards a earth tone black and cooler is towards a gun medal black.
  1. Outdoor protection for (milk?) paint
    By Kurt Whitley in forum Finishing School
    Last Post: 04-09-2008, 05:02 PM
  2. Got Milk???
    Last Post: 01-30-2008, 11:14 AM
  3. More on milk paint
    By ken werner in forum Finishing School
    Last Post: 03-06-2007, 06:58 PM
  4. seeking Milk paint recommendations
    Last Post: 02-23-2007, 01:17 AM
  5. Milk paint odor...
    By John Dow in forum Finishing School
    Last Post: 01-13-2007, 05:03 AM
