Results 1 to 10 of 18
Thread: Question for Dave
    May 2011
    Cape Cod, Ma.
    1,553
    Question for Dave
    I had to piece in the wood floor on the kitchen I am renovating. The house has white pine flooring which on first inspection looked like typical 1x stock that had been stained and then i later found out what seemed like "bartop" applied the varnish was so thick.... 12 50 grit belts and 40 discs of 60 grit later....
    Anyway, the new floor is that nice bright white of fresh cut pine. The old floor looks like it is older than the approximately 30 years it has been down. It is darker white with some brownish and reddish shading.
    I can get you a better picture of the new pine but this is what the old looks like.
    I have a coat of shellac and a coat of the enduro var on right now and before I do my final coats I wanted to tone down the whiteness of the new floor. I know I wont get an exact match and so does the homeowner. Spraying isnt an option I have to brush. I was thinking of adding a little red/brown tint in a thinned down mix like toner and brushing it on. What are your thoughts or do you have an easier fix?
    Thanks in advance!
    May 2011
    So. Florida
    268
    What if there's more than one Dave? Maybe you should have PM'd him instead.
    May 2011
    Cape Cod, Ma.
    1,553
    Quote Originally Posted by mike marvel View Post
    im tired its been a long day! give me a break!
    I guess I should have done that or just made it a general question. Dave was the first person who's name came to me when I was scratching my head trying to figure out what to do....... I certainly hope I didnt hurt any feelings....definitely not my intent.
    9,077
    After 12 50 grit belts and 40 discs of 60 grit I'd be a little loopy too.
    Apr 2009
    Outside the beltway
    5,261
    I would have toned the new floor with a vingar steel wood wash to get a match before you put on anything. Now you have found a good salution but you should try Burnt Umber 1st and then tweak it if you need to. Are you useing an acrylic finish?
    ::: Andrew Wyeth :::
    colonialrestorationstudio.com
    May 2011
    Cape Cod, Ma.
    1,553
    I wasnt aware of that trick.....
    This is the product I am using. http://www.generalfinishes.com/retai...based-urethane
    It's actually a wb alkyd based finish. I think I have some burnt umber dry pigment. so just mix a bit into a diluted solution of the varnish?
    Apr 2009
    Outside the beltway
    5,261
    ya , not much about 5% at 1st, you can always add toner. You may go up to 20% max But I don't see it seeing how light the floors are. Unless your talking about the difference of color tone in the hallway, I don't see enough difference of tone in the kitchen to warent using a toner. It will change over time and after a couple weeks living with it it will not be noticeable. Or do you have a better picture.
    May 2011
    Cape Cod, Ma.
    1,553
    Knew I forgot to do something when I was there today....
    I will get you a better pic tomorrow when I go back. The difference is very distinct and I much as I wish it were so I dont think it will darken enough...
    May 2011
    Cape Cod, Ma.
    1,553
    Here are some better pics showing the disparity.
    I took them from different angles as the sun was blasting through the window and there was a lot of shadow...... only one window in the room so the lighting is a nightmare sometimes
    Apr 2009
    Outside the beltway
    5,261
    12 hours of steel wool sitting in vinegar I knew you would have had a perfect match. 4 glaze I would probly use hickory a little bit of cherry mix. that should give you a color tone you need. Let me know if you need any help
  1. Calling Dave Richards.....Paging Dave Richards......
    By Ken Fitzgerald in forum Designs, Plans and Sketches
    Last Post: 12-06-2012, 06:03 PM
  2. Question for Dave Hawksford
    By Carol Reed in forum Finishing School
    Last Post: 03-24-2012, 05:36 PM
  3. Another question for Dave Hawksford
    By ken werner in forum Finishing School
    Last Post: 07-20-2011, 06:18 PM
  4. Calling Dave Richards! Dave, what's your twenty?
    By Bill Lantry in forum Off Topic Discussion
    Last Post: 07-11-2008, 09:46 PM
  5. OK Dave I need some help
    By Robert Mickley in forum Designs, Plans and Sketches
    Last Post: 01-28-2008, 02:25 AM
