Results 1 to 10 of 15
Thread: New tool Gloat........
    15,815
    Hey, I made this by hand, does it belong in the hand tools forum
    I was in real NEED of a curved bowl rest, the long straight rest I have leaves me with the tool a fair bit off the bowl in certain situations, and for the outside, I end up having to move the rest several times, not the best idea.
    I finally got the time today to spark up the torches, and the welder and get this done..........
    This is a fairly shallow bowl, but it works just fine, easy to get a single sweep on the last cut (no this is not anywhere near done, only rough shaped it).
    Again, same bowl (the second of the two Blue Spalted Keyaki) and it is shallow, but I think you can see how it will work.
    I had a heck of a time heating the 3/4" rod up hot enough to bend it, but I did get it done. I then drilled a 10mm hole in the 3/4" rod, and tapped a 8.5 mm hole for a 10 mm bolt. I ground a flat spot top and bottom on the 3/4" rod, and threaded the bolt in, once it was nice and tight, I welded the heck out of it.
    Used it only a bit, but it sure seems solid enough.
    I'd LOVE to buy a nice set of these, but the funds are slim right now, so this will have to do!
    Thanks for looking!
    Central CA
    797
    You da man Stu....you da man.
    Thanks, Mark.
    Custom Bonehead.
    My diet is working good. I'm down to needing just one chair now.
    "Just think how stupid the average person is, and then realize that half of them are even stupider!" --George Carlin
    Northville, MI
    507
    Nice, I need one of those.
    Jim
    stu, i don`t think you`re going to buy one made any better.....nice job! try to find some kind of vacuum rig before you get to sanding on this one ...tod
    Super stu, I need one of them.
    Steve Clardy Guest
    Looks good. I need to make me one one of these days
    Charleston
    917
    Stu, any addition to the arsenal is good, bu tthis one may deserve great status. Have fun
    The Heart of Dixie
    4,268
    I have got to get my welder fixed! I need some of these so bad.
    15,815
    Thanks guys, the hardest part was heating the rod up enough to be able to bend it, my little propane torches don't really put out enough heat!
    I need some kind of forge
    Austin, Texas
    1,461
    ...I need some kind of forge
    Why not? I can't think of anything else that hasn't been squeezed into the dungeon!
    I think I saw a list of potential customers the next time you fire up the metal tools!
    Charlie Plesums, Austin Texas
  1. New tool gloat.......
    By Eric Black in forum Off Topic Discussion
    Last Post: 09-27-2014, 02:57 PM
  2. New Tool Gloat
    Last Post: 10-23-2009, 12:00 PM
  3. Tool Gloat gone bad
    By Julio Navarro in forum Off Topic Discussion
    Last Post: 01-15-2008, 09:02 PM
  4. Tool Gloat
    By Tyler Howell in forum New Tools
    Last Post: 05-20-2007, 10:08 PM
  5. Tool Gloat!
    By Ben Werner in forum Turning Tool Questions and Show & Tell
    Last Post: 01-30-2007, 02:39 AM
