Results 1 to 7 of 7
Thread: Little Porclein work , again
    Apr 2009
    Outside the beltway
    5,259
    I took this job on to repair these 2 horses and a lil Buddha from Thailand. They were crushed in shipping. Because of the cost of the work involved just to put them back together the customer hopefully will be bringing them back to do the touch up. I spent some 11 hours put Humpty Dumpty back together again.
    Attached Thumbnails Attached Thumbnails P1010370.JPG   P1010365.JPG   P1010367.JPG   P1010366.JPG   P1010369.JPG
    ::: Andrew Wyeth :::
    colonialrestorationstudio.com
    May 2011
    Cape Cod, Ma.
    1,553
    wow a lot of work there. Good thing they had most of the pieces!
    What do you use to make a permanent repair? Epoxy?
    Apr 2009
    Outside the beltway
    5,259
    I use a glass epoxy. Dries in 6 minutes so mixing the amount needed for 1 to 3 pieces at a time and then cleaning the pallet and knife after each mixing takes time. But it also lets me double check the right piece to the right spot. Then there is the order in which things go back together. Out of all the pieces on both I only was missing 2 on the blue horse and 1 on the green. These were glazed and fired.
    North West Indiana
    6,099
    Will you airbrush them for the final fix? Or brush reglaze and fire?
    Jon
    Apr 2009
    Outside the beltway
    5,259
    Neither Jon, I use a Brushing Lacquer (gloss) and small brushes and mix oil pigments to match the areas. It takes a bit longer but it comes out looking great. You can not tell it's not fired and will hold up just as long. Well almost
    North West Indiana
    6,099
    That is similar to the pitcher handle then? Because that in the picture looked as if no repair had been made.
    Jon
    17,474
    i remember jarrod breaking that but i dont remember the fix afterwards??? where are the pics of that dave?
  1. Need help with work
    Last Post: 02-05-2015, 01:48 PM
  2. Work S.A.F.E.R
    By Jeff Bower in forum General Woodturning Q&A
    Last Post: 04-28-2009, 03:39 AM
  3. This elf's got his work cut out for him
    By Paul Hubbman in forum Off Topic Discussion
    Last Post: 12-18-2008, 12:58 AM
  4. Here's some of my work
    By Kenneth Lasota in forum Lathe Project Showcase
    Last Post: 03-21-2007, 03:05 PM
