Results 1 to 10 of 15
Thread: Little center points
    Tellico Plains, Tennessee
    4,353
    for the 4 pronged drive centers.... any one know where I might find a supply?
    I lost one in a pile of sawdust/wood shavings and even after spending an hour on hands and knees sifting through handful at a time, never found it... I have two of the drive centers, but one is now useless without the center point..
    Chuck
    Tellico Plains, TN
    Independence, Kentucky
    1,355
    Chuck did you try a strong magnet? It might just pick it up
    Central Illinois
    936
    A couple of suggestions:
    1- Buy a rolling magnet like the roofers use from some place like Harbor Freight.
    2 - Try Penn State Industries in Philladelphia.
    Bruce
    Bruce Shiverdecker - Retired Starving Artist ( No longer a Part timer at Woodcraft, Peoria, Il.)
    "The great thing about turning is that all you have to do is remove what's not needed and you have something beautiful. Nature does the hard part!"
    Oct 2009
    Harrisburg, NC
    140
    I would just take it to a local machine shop and see if they have steel rod to fit. Should not be more than a buck. You can order on line but shipping is usually way to high. Or go to a real hardwear store and get a bolt to fit.
    Cut the head off, insert, and file to a point on the lathe?
    All tyranny needs to gain a foothold is for people of good conscience to remain silent. Thomas Jefferson
    I always find stuff I lost under cushions on couch... keys, mobile, remote... did you check there?
    I don't suffer from insanity... I enjoy every minute of it
    Aug 2008
    Reno, Nv
    3,632
    My loser excuse of a bench has a metal frame on the bottom side. To this I hang a Snap-On flex magnet on a 18" handle. Since my back functions as well as a block wall...I pick up everything with it...and it picks up everything!!
    4,353
    Thanks for all the suggestions... problem is
    1. not sure where it actually fell... it was stuck in the piece of wood I was turning when I took it off the lathe..
    2. I didn't actually see it fall since I didn't see it in the wood.
    3. I've cleaned up the wood shavings.. one hand full at a time.. no joy
    4. I don't have a magnet in the shop.. have thought about getting one since I've dropped other things in the shavings, but always been able to find them.. by sifting through one hand full at a time.
    5. I'm thinking the magnet may cost more then then center points.
    6. I figured with the collective knowledge on this forum, I might find someone who has a source or knows of a source... think I'll try the rod idea... you can buy that at the borg's and a few minutes on a grinder will make a point..
    appreciate your help...
    Chuck
    Tellico Plains, TN
    11,833
    Quote Originally Posted by Mike Mills View Post
    They are tapered, like a mini MT. Would take some grinding and lot of time to do that.
    Jan 2011
    3,798
    3,132
    Chuck i use a old magnet out of a old speaker with a string tyed to it. Can you say cheap.
  1. More brownie points
    By Ken Cook in forum Flatwork Project Showcase
    Last Post: 02-16-2013, 06:06 PM
  2. Inexpensive safety center/dead center
    By Mike Mills in forum Turning Tool Questions and Show & Tell
    Last Post: 01-25-2012, 11:50 PM
  3. Cardinal Points
    Last Post: 07-16-2011, 03:53 PM
  4. Frankfurt WW points of interest
    By Peter Rideout in forum Off Topic Discussion
    Last Post: 11-16-2009, 07:03 AM
  5. Points of interest?
    Last Post: 04-17-2008, 05:42 AM
