Results 1 to 5 of 5
Thread: Painting wood
    Dec 2008
    Santa Claus, In
    4,779
    Painting wood
    If I make a couple small tables and paint the bottom of them. Would I need to prime them first or just go straight to coats of paint? The top would remain natural with coats of clear.
    What I am kicking around are some shaker style tables as holiday gifts. It started out small, but the list keeps getting added to. If the list gets any longer, I may have to contract the job out.
    Picture and free plan here, http://americanwoodworker.com/blogs/...ase-plans.aspx
    North West Indiana
    6,098
    Primer will hold the paint, provide you a consistent color. I think it is worth the extra step. Now do I follow my advice all the time? Nope, but when I don't, I find myself using extra paint and it has light and dark areas in it.
    Jon
    May 2011
    Cape Cod, Ma.
    1,553
    If you use milk paint you will probably be fine
    Seriously though. Some of the paints I have used advertise that they are "self priming". well....
    I would prime as it seals the wood and gives you a quicker build with your finish coats. Tinting the primer the color of the finish coat helps a lot too. Especially when you get into the reds.
    Apr 2009
    Outside the beltway
    5,255
    Quote Originally Posted by Rich Soby View Post
    Steve if you just painting for the effect, most undersides of tables were just primed with a rust red.
    ::: Andrew Wyeth :::
    colonialrestorationstudio.com
    Honolulu, Hawaii
    1,103
    Painting wood
    Dave, would that "rust red" you referred to be the same as red oxide?
    Thanks.
    Ah,,,to live in Paradise!
    Registered voting member
  1. Painting I will be doing
    Last Post: 09-05-2013, 12:01 AM
  2. Moose painting WIP
    Last Post: 01-19-2013, 03:59 AM
  3. Space painting
    Last Post: 11-21-2011, 08:51 PM
  4. Painting MDF
    By Bill Graupmann in forum Finishing School
    Last Post: 11-26-2009, 12:50 AM
  5. Painting Help
    By Michael Collins in forum Finishing School
    Last Post: 02-28-2007, 03:32 PM
