Results 1 to 3 of 3
Thread: Setting a grinder rest?
    Does anyone have any tricks for setting a bench grinder rest to approximately 25 degrees?. Ive been cleaning up some flea market finds and have needed to regrind some plane/chisels that were way off 25 degrees or had mutiple angles ground into the edge and its been taking me alot of time to get the grinder rest set and changed when the wheel wears.
    May 2011
    Cape Cod, Ma.
    1,553
    Veritas makes a grinding rest that will do plane blades and chisels and they have a skew sled as well. It comes with an angle guide that has 4 different angles. you set it on the tool rest and line it up with the wheel. Ive had good luck with it used in conjunction with their sharpening guide to run final honing on the stones.
    http://www.leevalley.com/US/wood/pag...38&cat=1,43072
    http://www.leevalley.com/US/wood/pag...76&cat=1,43072
    http://www.leevalley.com/US/wood/pag...36&cat=1,43072
    12,247
    Check out the instruction sheet and you can see how they do it with the kit.
    I have the kit and use it for my plane irons and chisels
    http://www.leevalley.com/US/shopping...s.aspx?p=43212
  1. Need help setting value - new item added!
    By Rennie Heuer in forum Neander Tool Questions and Show & Tell
    Last Post: 06-15-2011, 08:31 PM
  2. I have been setting up a new page
    Last Post: 03-09-2011, 06:30 PM
  3. Setting up a Miter Box
    Last Post: 01-24-2011, 11:38 AM
  4. setting up a Woverine
    By Frank Fusco in forum New Tools
    Last Post: 09-05-2008, 09:07 AM
  5. Shellac not setting up
    By Jay Lock in forum Finishing School
    Last Post: 01-08-2007, 05:00 PM
