Results 1 to 10 of 12
Thread: Have you seen this router jig? Found and Shop Made
    9,077
    I am usually the guy who can find something for you . . . well its my turn to ask. I have repeatedly seen this jig which consists of four aluminum extrusions (I think). In the catalog pic they are black and the picture shows a router sort of like what I show here. I plan to make one and just wanted a look at the commercial one before proceeding. Of course, I cannot find it to save my life
    The jig just creates an adjustable square or rectangle to act as a router template guide for rabbet recesses in picture frames and the like. I cannot find this darn thing anywhere although I swear, I stumble across it frequently when browsing supplier's catalogs. Am I just having a senior moment? Can anyone help me out with a source?
    12,262
    Any chance this is what you looking for.
    Its called a letter box jig
    http://www.diytools.co.uk/diy/Main/s...jig-lb-jig.asp
    Apr 2010
    Geneva Oh
    9
    Is this what you are looking for ? Varijig System Adjustable Frame
    Link listed Under Routing Jigs or http://www.youtube.com/watch?v=xtgbgwfBnak
    9,077
    Thanks for the replies guys. Ben, that's the one but, I still can't figure out where I have seen it. That's it, its definitely a senior moment. I probably NEVER saw it in a catalog. At any rate, here's my version made from MDF and some t-track I had up over the rafters if anyone is interested.
    The "L" brackets screw into one arm and a hex cap screw snugs a t-washer into the t-track to set the size. This will be used with a template guide or very carefully with a bearing guided bit due to the slot in the t-track.
    Despite having boxes full of misc jig doo-dads, I will have to run to the BORG for the L-brackets. I'll post a pic when I get it done. Thanks again.
    9,077
    Shop Made Version
    This turned out better than it has any right to. Seems to work well. I'll know if any enhancements are required after the first few projects.
    Attached Thumbnails Attached Thumbnails router-jig-frames 001.jpg   router-jig-frames 002.jpg   router-jig-frames 003.jpg
    13,363
    Very ingenious Glenn.
    I'm assuming you have something more than the the angle brackets keeping the sides from racking?
    Looks great!
    13,363
    Glenn, did you use this with a bushing or a bearing?
    I need to route out some recesses and this looks like a good way to do it. I like that it's adjustable. I think I might even have enough t-track to put something together.
    new york city burbs
    10,188
    maybe we should call you Red.
    Human Test Dummy
    Very slick solution, Glenn.
    9,077
    I used it with both. Even better, Sears had the original Trend unit on clearance, online for $40 so I snapped one up. The shop made one worked well though and was actually less fussy to setup than the commercial version ;-)
  1. Found mold in shop......can tools be saved?
    Last Post: 09-28-2012, 02:10 AM
  2. Shop made router mortising jig
    By Alan Bienlein in forum Jigs and Fixtures
    Last Post: 07-10-2012, 02:37 AM
  3. I think I just found my new shop investment
    By Rich Soby in forum New Tools
    Last Post: 02-12-2012, 04:25 PM
  4. Found my shop today
    Last Post: 11-26-2010, 10:36 PM
  5. I Found A New Way To Get A Clean Shop
    By Jim C Bradley in forum Off Topic Discussion
    Last Post: 06-22-2010, 12:08 AM
