Results 1 to 4 of 4
Thread: Rail and Stile
    Dec 2008
    Santa Claus, In
    4,779
    Rail and Stile
    OK I need little help figuring out rail and stile widths. The face frame will be 1 1/4" so what should I make the door rail and stiles? I am thinking somewhere around 1 1/2"
    This is on a chimney cupboard of sorts. So it will be taller than wide. Main cabinet is figuring out around 22" x 84". I have a hole to hit so stuck with the 22" somewhat because of the cove molding. First time I have ever figured the very top and worked down.
    Try this software...it is free and has an enormous library free online.
    I have not used it yet, but just been playing with it. It looks like it is what you are looking for.
    http://www.ecabinetsystems.com/
    Anybody can become a woodworker, but only a Craftsmen can hide his mistakes!
    The Bible tells us to love our neighbors, and also to love our enemies; probably because they are generally the same people.
    May 2011
    Cape Cod, Ma.
    1,553
    Steve I normally use an 1-1/2" stile on my face frames and a 2-1/4 stile and rail on the doors. If you are using a 3/8 cutter for the depth of the panel groove size your panel 3/8 wider than its opening, if you are using 1/2" panel groove then make the panel 5/8 wider than its opening. this is when using 1/4" spaceballs or the ones I get from woodworkers hardware.
    My face frame rails vary depending on the application, ie moldings, undercabinet lighting etc.
    The cabinets in the cherry kitchen I have posted are those proportions. They have a 3" top rail and 2" bottom rail on the ff with 1-1/2" stiles.
    hope that helps
    Dec 2008
    Santa Claus, In
    4,779
    Dom, that is the second time today I have seen that software. Strange thing it is done by Thermwood. They are right down the road.
    Thanks Rich. I mocked it up real quick and got approved for 1 3/4. So off we go.
  1. Making Rail & Stile Glass Doors.... Need some help....
    Last Post: 02-13-2011, 03:05 AM
  2. seeking rail & stile bit set
    By Bill Simpson in forum General Woodworking Q&A
    Last Post: 04-27-2009, 08:51 PM
  3. Aligning Rail & Stile Router Bits
    By John Clasen in forum General Woodworking Q&A
    Last Post: 04-02-2008, 06:34 PM
  4. Rail and Stile profile cutting
    By Matt Dunlap in forum General Woodworking Q&A
    Last Post: 05-12-2007, 10:00 PM
  5. Rail and Stile Question
    By Ed Nelson in forum General Woodworking Q&A
    Last Post: 05-10-2007, 07:04 PM
