Results 1 to 6 of 6
Thread: Another re-arrangement
    Jan 2011
    3,798
    Had to....needed to get a real heat source back in the shop...I sold my last wood-stove and have been using those little ceramic heaters...no more!!!
    But what an undertaking...figured a day or two shuffling things around...probably would of been that short if I hadn't used my eyes ...
    dived right in with out thinking{par for the course in these boots}...mess city...
ID:	58905 Click image for larger version.
    did manage to somewhat straighten/corral the shorts{I have a hard time throwing anything away, but the wood stove will be well fed this year }
    Managed a to incorporate the cheap router into the table saw table...that's the old fence laying against the TS fence, don't know if I'll keep it of notch the TS fence...6 in one hand, half a dozen in the other...
ID:	58907 Click image for larger version.
    made some slide thingy's for the benchtop tools, makes it easy to pull out one without the others being in the way. I can peg/pin the ply-bases to the slides if vibration requires..and I also added a couple of slide-in supports for left of the mitre saw, the right side I use a roller guide when needed...
ID:	58909 Click image for larger version.
ID:	58910 Click image for larger version.
    a couple of current overview shots...
ID:	58913 Click image for larger version.
    still a ton of stuff I'd like to do, and will, but at a much more leisurely pace...least things are back to useable for now...
    oh yeah, I can actually get to my compressor to drain it on a regular basis now...I filled up a 9" x11" baking pan 'twice' , it was a pain to get to before, now I just move a chair & the shop vac
    10,604
    Great looking shop Ken but way too neat
    The sliding things are pretty ingenious
    Constantine, MI
    7,891
    Pretty cool (uh, warm?) Ditto on the slides.
    www.wrworkshop.com
    Dec 2008
    Santa Claus, In
    4,779
    I like it, looks good.
    Rule of thumb is if you don’t know what tool to buy next, then you probably don’t need it yet.
    12,260
    I luv sbop tours. Bet you cant wait for winter eh Ken.
    That's quite an improvement. Ditto me on the slidey things. Great idea.
  1. Shop arrangement input wanted
    Last Post: 03-14-2007, 11:59 PM
  2. Shop arrangement question
    Last Post: 11-25-2006, 01:28 PM
