Results 1 to 9 of 9
Thread: Drill Press Table
    Jun 2010
    Croton, Ohio (about a half hour NE of Columbus)
    154
    Drill Press Table
    I built myself a new drill press table. The top and fence are from a piece of melamine I had laying around and I trimmed it up with some scrap pine. The vice cranks came off an old workmate type unit that I took apart a few years ago. I plan to eventually add some track for clamping and I'll most likely cut a circle in the middle for a sacrificial insert.
    Attached Thumbnails Attached Thumbnails 100_2579-750.jpg   100_2580-750.jpg   100_2581-750.jpg   100_2583-750.jpg
    Los Angeles, CA
    2,668
    That looks very solid and should work just fine.
    Jan 2011
    3,798
    Nicely done!
    10,604
    Sure looks like it will get the job done. Very nice
    12,260
    Very cool i like the recycled workmate cranks. Thats putting them to good use.
    The fence cranks are a great idea. You'll get a lot of use out of that table.
    Those cranks are great!
    As others have said, I love the crank idea. Really really cool!
    13,361
    Awesome. Nice job recycling the crank hardware. Should make it easy to dial into some accurate cuts
    Jun 2007
    4,944
    A good drill press table is a wonderful thing. It increases WW enjoyment by making drilling easier. It also makes drilling more accurate and safer.
    You will Really enjoy it when you get some Tee track mounted. I mounted an extra pair of Tee tracks parallel to the original pair. The new tracks are closer to the drill. They really help with hold downs.
    The fence really pays off by allowing a series of holes to be Exactly the same distance from the edge. It is also a great help when doing overlapping Forstner bit holes.
    Way to go man!
    Enjoy,
    Jim
    ps. listen to me, a relative beginner telling you how to use your tool.
    VOTING MEMBER
  1. Drill Press Table
    By Darren Wright in forum Jigs and Fixtures
    Last Post: 10-28-2014, 03:22 AM
  2. Drill press table
    By Roger Tulk in forum Jigs and Fixtures
    Last Post: 05-01-2013, 08:52 AM
  3. Drill press table
    Last Post: 01-16-2012, 05:58 AM
  4. Drill Press Table Add-on
    Last Post: 09-10-2009, 09:48 AM
  5. Drill press table???
    By Chuck Beland in forum General Woodworking Q&A
    Last Post: 02-16-2008, 06:42 PM
