Results 1 to 10 of 14
Thread: Coaster Set
    Sep 2007
    Bloomington MN USA
    268
    Coaster Set
    I have been going to do this for a long time,but just never seem to get around to it. The coaster set we have is much to small for a larger size glass or cup. So This was the time. I have some Mahogany Flooring along with some Maple flooring. A relative of mine does flooring for his work. So I get some of his scraps. For some reason Flooring is much harder than your regular wood type. AnywayI got all the pieces laid out and ready to rip and after ripping them to size I glued them up and then ran them through the plainer.
    Cut every thing to length and did the glue up of the carcase.
Name:	Ready to rip to size.JPG
Name:	Plane to thickness.JPG
Name:	Carcase glue up.JPG
    If you make a mistake it was part of the original plan!
    Sep 2007
    Bloomington MN USA
    268
    Now it was time to cut the feet, they needed a lsight round over about 1/16"
    Then glue feet to the carcase. While they are drying I will rout out the area in the coaster for the cork. Took a little work to make up the template as I had no hole saw or forsner bit large enough, but I did find a wing cutter I bought way back when. It worked great once I found a safe way of useing it.
    Applied BLO to all parts and let dry.Set up my Spray Booth on top of my bench and brought in the turn table. Sprayed a couple coats of water base clear & waxed. Glue the cork on and even put some felt pads on the bottom
    of each.
Name:	Redy to cut feet.JPG
ID:	59002 Click image for larger version.
Name:	Slight round over.JPG
ID:	59003 Click image for larger version.
Name:	Glue feet on.JPG
ID:	59004 Click image for larger version.
Name:	Template to rout for cork.JPG
ID:	59005 Click image for larger version.
Name:	BLO applied.JPG
ID:	59006 Click image for larger version.
Name:	On the turntable for finish.JPG
ID:	59007 Click image for larger version.
Name:	My delux spray booth.JPG
ID:	59008 Click image for larger version.
Name:	Ready to glue up cork.JPG
    It all came to gather pretty well. This is my first attempt to try and show what I was doing, not sure if it is to jumbled up or not. Let me know if I should post it differently. Any way it was fun doing it. More work than
    making the project. I am not all that comfortable with taking the pictures. I keep forgetting to take a picture at the proper time.
    30,017
    That's a very nice coaster set, Ron. Great job.
    13,361
    Now that should come in handy on those hot days that make the glasses sweat! Well done!
    17,472
    looks good to me ron and all yu need is the bottle to fill the glasses..
    Yorktown, Virginia
    5,015
    Man...someday I want furniture good enough to need coasters. Those are beauties. Nice job Ron!
    10,604
    Great design Ron. They came out fantastic
    Los Angeles, CA
    2,668
    Coasters look super nice.
    Thanks for posting all the pictures detailing the process.
    Sep 2007
    Plainwell, Michigan
    4,857
    Awesome set of coasters and holder Ron I know I am going to sneak that design if you don't mind
    Jan 2011
    3,798
    Beautiful!
  1. Been a few roller coaster days for me but the ride is over..
    Last Post: 01-24-2013, 01:20 AM
  2. Alpine Roller Coaster
    Last Post: 11-23-2011, 02:34 AM
  3. Coaster Plates
    By Stuart Ablett in forum Handtool Project Showcase
    Last Post: 05-09-2010, 06:40 PM
