Results 1 to 10 of 21
Thread: Need help - Table leg design/wood chalenges
    Constantine, MI
    7,887
    Question Need help - Table leg design/wood chalenges
    I've just received a commission to produce an end table, probably in walnut, that looks "just like this but without the shelf".
ID:	59026Click image for larger version.
ID:	59027Click image for larger version.
    Can anyone point me to a tutorial or magazine article that explains the best way to make these legs?
    Also, a design query - Should we go with nothing in place of the shelf, or, do you think the design will require stretchers?
    www.wrworkshop.com
    13,427
    I'd have to find a tutorial, but basically you'll cut the curves on the bandsaw. Save the cut-offs as you'll need to tape them back onto the legs to keep them square for cutting the other sides of the legs.
    Here's a video, same idea as cutting cabriole legs, this guy uses hot glue instead of tape:
    http://www.mefeedia.com/video/28294559
    4,551
    Look up making a Cabriole leg. I found this site http://www.woodcraft.com/Articles/Ar...?articleid=660
    A Turn N Time
    Frog Pond Guitars
    4,551
    Ya beat me by a few seconds Darren
    A Turn N Time
    Frog Pond Guitars
    Cut them just like a cabriole leg would be cut out. Just like they do here.http://www.woodcraft.com/Articles/Ar...?articleid=660
    Constantine, MI
    7,887
    WOW, that was fast. I kind of expected they might cut similar to a cabriole leg.
    Now, on to the second question - stretcher or no stretcher? Or does it matter?
    www.wrworkshop.com
    13,427
    Depending on the joinery at the top, wouldn't think you'd have to have a stretcher, but depends on what the client wants and how it's going to be used. If it's going to hold a marble sculpture or a delicate piece (that could fall if wobbly), it may be warranted. For an end table that holds a lamp and a cup of coffee once in a while, it looks like it would look good without any.
    17,470
    darren beat me to it but i fully agree with his thoughts rennie..and even if it held a heavy weight good mortise and tenons will hold alot more than most realize..
    May 2011
    Cape Cod, Ma.
    1,553
    Rennie,
    Check out this book.
    "Circular Work in Carpentry and Joinery" by George Collings
    It has everything you could ever need on how to cut curves compound curves arches twists.
    It's bailed me out of many a head scratching session!
    http://www.barnesandnoble.com/w/circ...band%2bjoinery
    Rennie.....the Mini-Max website used to have a video of cutting a cabriole leg that explained pretty well how to do it.
    Ken
  1. Round Kitchen Table...is this design even possible?
    By Douglas Stack in forum Designs, Plans and Sketches
    Last Post: 06-19-2015, 01:53 PM
  2. End/Side table design
    By Matt Ducar in forum Designs, Plans and Sketches
    Last Post: 01-01-2013, 04:03 PM
  3. Artist Table Design
    By Ed Nelson in forum Designs, Plans and Sketches
    Last Post: 11-30-2007, 03:50 AM
  4. Wood Design (part 2)
    By Aaron Beaver in forum Designs, Plans and Sketches
    Last Post: 11-24-2007, 01:59 AM
  5. Wood orientation design
    Last Post: 11-21-2007, 07:24 PM
