- Constantine, MI
Thanks Charlie. I was planning on cutting the square so the seam ran front point to back poit (clear as mud?) so the grain patterns would match on each side.One problem with legs is that the quartersawn side (with the fine grain) looks great, and the flat sawn side (with the cathedrals) looks ugly. I sometimes cut a veneer from the quartersawn side and glue it to the flatsawn side to make the leg prettier. It sounds like you have a great opportunity to solve the grain problem when you glue up the blank for the leg.
With big aprons like that, I don't believe you will need stretchers.
