Results 1 to 6 of 6
Thread: My attempt at turning a bowl
    May 2011
    Cape Cod, Ma.
    1,553
    Well this one stretched out my tooling.... I now know that if I am going to start doing this for fun and maybe sell a few. I am going to have to upgrade my chisels, gouges and scrapers. As well as tool rests. This piece has some heavy checking on the side but I got a lot of tear out from over reaching as my tool rest wouldn't fit inside at the angles I needed to make the cuts.
    I need to work on my proportions as well. I think the neck is a bit too long for the base.
    2 coats of tung oil spun on and I will put a couple more on before parting it off.
    North West Indiana
    6,099
    Cool! The shape kind of reminds me of the old brass spitoons!
    Jon
    May 2011
    Cape Cod, Ma.
    1,553
    Hahaha it does doesnt it! I was trying to roll the top so it flared back on itself. The gouges and scrapers I have arent small enough to get in and roll the lip the way I wanted to........
    North West Indiana
    6,099
    With gluing it on the faceplate. How do you finish the bottom? Do you cut it off of the face plate using a parting tool??
    Jon
    Pieces like this are a good way to discover the limitations of your tools (and your experience). I agree with you about the proportions, but until you turn a few that are off, it's hard to know when one is right. You seem to have a good eye and an honest approach to critiquing your own work, so I suspect your forms will improve quickly.
    You picked a challenging form, too. For some reason, a lot of beginning bowl turners start off trying to make bowls flare out inside somewhere after the rim. I know I did.
    May 2011
    Cape Cod, Ma.
    1,553
    Quote Originally Posted by Jonathan Shively View Post
    Yes I will turn a small base then part it off and hand sand and finish.
    I learned it watching a guy turn on youtube. Check out haydenhd on youtube he has quite a few turning videos and that is how he attaches a lot of his work. I was a little skeptical till I tried to pull the piece off of the waste block.
    Thanks Vaughn, yeah I do tend to want to run before I can walk. Well the "list" is growing for new tools. My wife wants me to make her a big bowl like a salad bowl. I already told her I'm gonna need a bigger lathe! She said "you have no more room in there" I said I already have the shop rearranged and know exactly where it will fit! So now the uphill battle begins (aka begging and doing lots of chores I wouldnt normally do......)
    There were a couple of times when I was hollowing out that I was one of the scrapers and the small bowl gouge flex to the point I thought the were going to snap. That is why the interior isnt as refined as it should be. I reached the end of what my tools and tool rest will do.
  1. My first bowl (or attempt thereat...)
    By Roger Tulk in forum Turning Tool Questions and Show & Tell
    Last Post: 08-09-2014, 03:16 AM
  2. first attempt at turning an ornament.
    By Dan Noren in forum Lathe Project Showcase
    Last Post: 10-31-2012, 02:13 AM
  3. First attempt at segmented bowl
    By Chuck Ellis in forum Lathe Project Showcase
    Last Post: 03-17-2009, 09:52 AM
  4. My 2nd Attempt at Turning a Bowl
    By Sean Wright in forum Lathe Project Showcase
    Last Post: 06-23-2008, 05:29 AM
  5. Bowl attempt #7 - and some success ...
    By John Bartley in forum Lathe Project Showcase
    Last Post: 09-27-2007, 10:41 PM
