Results 1 to 5 of 5
Thread: Mortise Tenon ?
    Dec 2008
    Santa Claus, In
    4,779
    Mortise Tenon ?
    When making a mortise and tenon joint, how long should the tenon be? Is there a set rule? Guild lines?
    Rule of thumb is if you don’t know what tool to buy next, then you probably don’t need it yet.
    Central NY State
    3,374
    Well, one way to do it is through. All the way to the other side. If you don't want to see the end of the tenon, then going about 2/3 of the way is fine, but basically, I think you can make it any size you want.
    On M&T apron to leg joinery, I usually go a little shy of when the two tenons meet, and end them with a miter. On doors, it's pretty much whatever you want.
    Independence, Kentucky
    1,355
    I usually make them about an inch long for apron/leg joints, and I have not had a problem so far. I use a plunge router to cut the mortice. It depends on what the situation is I think. I did a sleigh bed and I made the joints an inch and a half into the end posts, so far so good.
    Chuck
    Mar 2010
    Decatur, Alabama
    518
    Depends on what it's doing, size, whether it's pinned. I like to go 3x the thickness of the tenon if I can. Not sure if I read that somewhere or not, but it works pretty well.
    I've always wondered on a pinned joint how much wood you need to leave past the pin. The few I've done, I left about 2x the pin diameter, but that was just a guess.
    Bellingham
    2,449
    Quote Originally Posted by Steve Southwood View Post
    I found this link to be very helpful when I was laying out my first tenons and wondered about the same things. Just remember what they say about rules.
    http://www.geoffswoodwork.co.uk/mortise01.htm
  1. Round Mortise with Square Tenon?
    By Bob Beasley in forum General Woodworking Q&A
    Last Post: 10-01-2015, 02:59 PM
  2. 114 Mortise & tenon joints
    By Jim DeLaney in forum Flatwork Project Showcase
    Last Post: 04-14-2010, 10:48 PM
  3. Three Quick Mortise and Tenon Questions
    By Chris Marlor in forum General Woodworking Q&A
    Last Post: 05-25-2009, 03:47 PM
  4. Tenon vs. Loose Tenon
    Last Post: 04-13-2007, 11:18 PM
  5. Mortise and tenon Q's... Workbench base
    By Brent Grooms in forum General Woodworking Q&A
    Last Post: 01-13-2007, 06:14 PM
