Results 1 to 2 of 2
Thread: Homemade Chatter Tool
    My first attempt at making a chatter tool. I somewhat followed the instructions HERE.
    I used a 3/4"x6-1/2" hex bolt for the body and mahagony for the handle. The blade is a ground down jigsaw blade. Once the hex head was cut off and the threads ground off with an angle grinder, the bolt was drilled then chucked in a Beall chuck and turned with the angle grinder being used as a cutter. What a mess. 'Glad I put newspaper on the lathe and bench. It made the cleanup easier. (Yes, I used the Jet Mini). After that, it was simple enough to drill a 9/16" hole in the wood, turn the handle, insert and tap the tool head and add the copper fitting ferrule. Since the tool is for me I left many of the scratches on the bolt. Just wanted to get it done!
    I realized that besides using this for chatter work, I can make cutting inserts from "D" size drill rod.... beading, parting, that sort of stuff. I'm also looking into grinding down some gears I found at my local surplus place and putting together something like the Sorby texturing/spiraling tool. Maybe next weekend
    Attached Thumbnails Attached Thumbnails ctool1.jpg   ctool2.jpg   ctool3.jpg   ctool4.jpg
    15,816
    Joe that is fantastic, GREAT job!!
  1. Plane chatter
    Last Post: 05-08-2012, 03:47 AM
  2. Homemade articulating hollowing tool
    By Raymond Sprouse in forum Jigs and Fixtures
    Last Post: 05-26-2011, 10:24 AM
  3. Homemade Bowl Coring Tool
    By Raymond Sprouse in forum Turning Tool Questions and Show & Tell
    Last Post: 04-20-2011, 02:31 AM
  4. Larry Marley Chatter tool
    By laurence moughan in forum Turning Tool Questions and Show & Tell
    Last Post: 01-29-2009, 09:51 AM
  5. chatter in oak
    By Jiggs Elphison in forum General Woodworking Q&A
    Last Post: 07-26-2008, 01:37 PM
