Results 1 to 10 of 18
Thread: Folding leg ideas?
    Atlanta, GA
    194
    Folding leg ideas?
    I need to make a small stool, roughly 30" long by 11" wide and 15" high. It has to be portable, so I was thinking along the lines of some kind of folding legs. It'd be nice if the legs could lock up in the folded position and down in the > 90 degree position so that it's nice and stable. Anyone have any ideas for something like that? Most of the locking hinges I've seen are 90 degrees and they don't really lock that well. Maybe just a hinge for the foot and some sort of sliding thing to interfere with it's closing.
    12,256
    Charlie i thought i had seen a hinge over on the hardware at Lee Valley that would do what you want. But could not find it.
    Anyhow why not split the two tasks.
    1) Leg retainer for folded legs
    Use the magets and a metal disc to hold them folded position like a cuppboard door. If you use the metal cup type of rare earth magnets and a forstner bit you could conceal them by sinking them into the bottom of the bench seat.
    2) Leg hinge could be all sorts even a dowel through the legs with two trunnions on either end allowing the leg to pivot.
    Its the keeping it open i would be more concerned with. Somehow you need a stretcher in the middle.
    Do a sketch of what you looking for and ask for input.
    I assume you have seen the commercial ones and are looking for a shop made solution but, just in case; for about $10 a pair, these will get your there: http://www.rockler.com/gallery.cfm?O...Select=Details
    12,256
    Thats not fair Glenn.
    Atlanta, GA
    194
    Well Glenn, I looked at LV and Woodcraft and didn't see anything like those- they look pretty good, thanks.
    Rob, great idea on the magnets to keep the legs up. Still pondering a shop-made solution for locking down.
    17,472
    had you thought of 3 legs and have only one need to be locked or pinned with a clasp pin.the seat could be permanently anchored and just fold down with the legs pivoting on a center axle.
    Catalunya
    4,632
    You could fix the three legs to the seat with hinges and then have a triangular piece of 1/3" of plywood with selicirlular recesses on each vertex. One leg would have a metal rod going throug it and fix it to one of that reces to behave like a hinge. then you would unfold the seat and log the legs by unfolding the triangle to horizontal so that the other two legs fit on the recesses of the vertex, actian as if it was a stretcher.
    I hope to have conveyed the idea properly, if not I can make you a sketch.
    Best regards,
    Toni
    May 2011
    Cape Cod, Ma.
    1,553
    how about a fold down stretcher as well? have the legs drop left and right and the stretcher drop front to back then index into a stop? you could use regular hinges at that point and if you stagger them correctly only need one release that when activated the legs drop and the stretcher swings into place
    Atlanta, GA
    194
    Thanks for the ideas guys. Larry, I like the 3-leg idea, I think that should be stable enough. Toni/Rich- good ideas on the stretchers. I'll try and sketch up a couple things.
    12,256
    Make sure to show us the results Charlie. or we will arrange for Lucy to come over with Beethoven.
  1. That folding table I liked???
    By Carol Reed in forum New Tools
    Last Post: 06-06-2014, 12:54 AM
  2. building a folding sawbuck
    Last Post: 11-30-2013, 03:43 AM
  3. Folding Party Stands
    By Mike Henderson in forum Flatwork Project Showcase
    Last Post: 06-21-2013, 03:21 PM
  4. Folding Brackets
    Last Post: 09-16-2011, 12:29 PM
  5. Folding Utility Knives
    By Wes Bischel in forum Hot Deals
    Last Post: 09-07-2007, 12:02 AM
