Results 1 to 10 of 12
Thread: Dewalt 733 Planer Thicknesser Problem
    Aug 2011
    Mallorca Mediterranean Sea
    6
    Cool Dewalt 733 Planer Thicknesser Problem
    Hi. I have retired to the Island of Mallorca in the Mediterranean and Forums are my lifline!! Can anyone help me with a recent problem? The DW733 Planer Thicknesser has a safety "No Volt Off" switch (Green and Red Button) and has worked fine for several years. Suddenly it only works when I am actually holding the green button on - as soon as I release it - it stops. I tried another switch that I know works and exactly the same problem. Motor sounds fine, brushes are as new and it is pretty clean generally. What can I look at? What can I hit?
    Thanks in anticipation Peter
    Hello Peter and Welcome. The switch you describe sounds like a magnetic switch or at least a voltage-present relay controlled switch. When you say you replaced it with a switch that you know works, was this a 100% replacement? That is; was the actual physical switching mechanism and the relay/mag assembly swapped out?
    11,826
    You may have a faulty overload/overheat reset on the planer.
    Look for a reset button and push it. That may fix everything. Or if that is faulty it might need replacing or by-passing (probably not a good idea). My Grizzly planer has an overly sensitive overload switch. When replaced all works well.
    Aug 2011
    6
    Thanks Glenn - yes the swapped out switch was exactly similar (voltage present type). Another member has suggested a possible problem with the overload reset button so that will be my next check. Really appreciate quick response. Good Luck Peter
    Aug 2011
    6
    Thanks Frank - I am on the case - the reset button feels dead (No resistance when I press so may have failed) Thanks again Peter
    Aug 2011
    6
    Hi Frank. I just temporarily bypassed reset switch and no change. Still scratching my head. Regards Peter
    Honolulu, Hawaii
    1,103
    Dewalt 733 Planer
    Peter,
    Welcome. Try checking for continuity accross your "stop" switch, with the machine unplugged. If that shows an open circuit, (it should only be open when you push the stop button) the planer will start, and run, as long as you hold it (the start button) on. The stop switch is supposed to hold that circuit closed until you open it by pushing the stop button.
    Aloha, Tony
    Ah,,,to live in Paradise!
    Registered voting member
    11,826
    Quote Originally Posted by peter nash View Post
    Well, at least, the head scratching part usually feels good.
    Aug 2011
    6
    Thanks Tony. After an hour in the local Taverna last night - the "Leetle Grey Cells" they started to work and I am embarrased to say have now resolved the problem. The actual "No Voltage Release" switch was faulty and the replacement I tried had the beginnings of a similar fault. The internal solenoid has two insect like antenna terminals. The original had broken off too short to make a connection and the second was making an intermiitent connection. I just assumed (big mistake) that the second switch would be good. Thanks for your time and good island living. Regards Peter
    Aug 2011
    6
    Thanks Glenn . After an hour in the local Taverna last night - the "Leetle Grey Cells" they started to work and I am embarrased to say have now resolved the problem. You were spot on. The actual "No Voltage Release" switch was faulty and the replacement I tried had the beginnings of a similar fault. The internal solenoid has two insect like antenna terminals. The original had broken off too short to make a connection and the second was making an intermiitent connection. I just assumed (big mistake) that the second switch would be good. Regards Peter
  1. Thicknesser tuning ? I found the problem!! UPDATED
    Last Post: 04-28-2016, 05:51 PM
  2. Dewalt 735 planer
    By Scott Donley in forum Hot Deals
    Last Post: 02-23-2010, 01:31 AM
  3. DeWalt DW733 Problem
    By Bob Gibson in forum General Woodworking Q&A
    Last Post: 10-06-2009, 08:07 PM
  4. DeWalt 733 planer
    By Royall Clark in forum General Woodworking Q&A
    Last Post: 01-17-2009, 08:22 PM
  5. Dewalt CMS problem/parts help please
    By Paul Greathouse in forum General Woodworking Q&A
    Last Post: 07-22-2007, 02:25 AM
