Results 1 to 10 of 11
Thread: Deck skirt enclosed
    12,251
    Deck skirt enclosed
    Ok so i had my deck made for me when i arrived in Canada but now i got a feel for the local ways i finally decided to get round to putting on the skirt.
    What a job. Between the grade slope and the heights around the deck each piece of lattice was a custom fit.
    I feel like a trim carpenter took an age to do.
    So i started with putting down stone and then put down a 4x4 post flat on the stone. Pounded that down and used 2x4 and framed up to the deck. Then 12 inch nails through 4x4 into ground. Strip of half 2x4 on top of 4x4 set back for lattice to but up against.
    Fit lattice in and then trimmed out with strips all the way round. All screwed in place. Deck is also all screws thats how i spec d it at the time.
    Deck is topside cedar undercarridge pressure treated.
    I was not going to spring for cedar lattice way too costly and i am about to restain the whole deck after stripping it courtesy of Behr paints so the stain will change the pressure treated lattice to look like cedar. Good enough i dont see it and Bunny Fu fu wont mind i am sure and i could not care less about NN.
    Then on the side i improvised and made a access door using a lattice and my shop machines.
    Cut a piece of 1x6x8 in half both ways. Then dadoe an edge for the lattice to ride in and sandwhiched the lattice between the pieces top and bottom. Added same set up on the side and mitred the corners. Added some ply triangles used loads of glue and voila one access panel. Sturdy enough i dont go under there and now it will be the hide of out of wasps and bumble bees.
Name:	Deck lattice right hand side reduced.jpg
ID:	59477 Click image for larger version.
Name:	Deck lattice left hand side reduced.jpg
ID:	59478 Click image for larger version.
Name:	Access door on left hand side reduced.jpg
ID:	59479 Click image for larger version.
Name:	Access panel open reduced.jpg
ID:	59480 Click image for larger version.
Name:	Access panel door  frame detail reduced.jpg
    Next up Stain.
    13,360
    And it's not even labor day yet (Well, almost down here in the states. Do you have an equivalent up there?)
    Looks like a nice and useful project. Well done!
    12,251
    Well Brent our Labor day is this Monday. Thanks for the comments.
    Constantine, MI
    7,890
    Looks like you did a fine.....wait a second.....what's that noise.... do you hear buzzing?
    www.wrworkshop.com
    Yorktown, Virginia
    5,014
    Good looking skirt. I need to do the same with my deck and will 'borrow' your technique for the access panel. I think I will also stretch some screening on the inside all the way around to keep the flying things out. We have carpenter bees down here that love drilling holes in the deck supports.
    30,015
    ...i finally decided to get round to putting on the skirt.
    Taken out of context, that could be quite an interesting statement, Rob.
    Glad it was your deck, and not you. Nice job, by the way.
    10,604
    Great job Rob
    12,251
    Thanks guys , Vaughn you have the sharpest brain and a wonderful sense of humor. If i worked with you i would be getting caught out every sentence i speak. I stepped into that one alright.
    North West Indiana
    6,098
    Very nice Rob. Looks like a great space. Going to use it to put your lawn furniture away come winter?
    Jon
    17,472
    rob,, suggestion on your corners on the frame work. fill them in flush so they dont collect snow and melt and then start the rot process earlier than needed.. the treated will stand up but the ply corners won without the fillers to make the snow fall off when melting
  1. Adding Drawers to an Enclosed Machine Base
    Last Post: 10-20-2012, 07:03 PM
  2. Deck Refinish
    Last Post: 05-05-2012, 09:55 PM
  3. Deck rejuvenation
    By Rob Keeble in forum Finishing School
    Last Post: 09-10-2011, 04:21 PM
  4. Deck over a slab
    By Mike Rathe in forum General Woodworking Q&A
    Last Post: 06-27-2008, 08:47 PM
  5. Enclosed dust collector shed
    By Virgil Huffman in forum Carpentry and Construction
    Last Post: 04-24-2008, 12:15 PM
