Results 1 to 10 of 11
Thread: Best drill bit for end grain boring?
    Jun 2010
    Boston, MA
    134
    Not really a "woodworking" question of the usual variety:
    I had two pine trees removed at the beginning of the summer. I want to drill some holes into the stumps & add some sodium metabisulfite to help break things down.
    The woodworking portion of this question is what kind of drill bit is best for drilling into end grain wood? I figure my paddle style bit isn't going to be the best option, but I'm not sure what style bit I should try.
    Anyone have some experience to share?
    May 2011
    Cape Cod, Ma.
    1,185
    Any twist bit or auger should do fine. Depends on how large you want to drill the holes. Twist are fine up to a half inch then you may want to go with an auger bit.
    10,882
    Antique shops are your friend.
    Find a brace and look for an auger bit about 3/4" or larger.
    I have several with a couple that have extended length.
    I almost sold all my Neander stuff but find I'm still reaching for this stuff about once or twice a year.
    9,383
    Quote Originally Posted by Matt Ducar View Post
    Wouldn't C3N3H5O9 be faster?
    Jun 2010
    Boston, MA
    134
    Thanks for the tip on using the auger bit rather than a twist bit -- wasn't sure which would be better. Swung by the new HF store and got a 3 piece auger bit set that has a 1" bit for under $20.
    Jun 2010
    Boston, MA
    134
    I thought about using C6H2(NO2)3CH3 but then decided it wouldn't be faster.
    I figured it would take about an hour to place the charge and remove the stump.
    Then there would be the getting arrested, court hearings, lawyer fees, & otherwise dealing with the aftermath.
    The stump would probably have rotted away on its own before I got done with the mess created
    Jan 2011
    Michigan
    1,989
    yeah if the intent is to remove the stump and put in a built in pool
    Dec 2008
    Portland, Oregon
    1,230
    Wasn't he R2D2's partner's 2nd cousin on his mother's side???
    Jesus was a Woodworker
    Jun 2010
    Boston, MA
    134
    Quote Originally Posted by Dan Mooney View Post
    Sorry Dan, some of us are also geeks.
    C3N3H5O9 = Nitroglycerin
    C6H2(NO2)3CH3 = TNT = Trinitrotoluene = Dynamite
    NH
    3,351
    http://www.wikco.com/stump.html One of these would be about 1/4 the cost of Brent's method.
    Dragon's Paradox
    Stupid hurts.
