Results 1 to 10 of 23
Thread: Why do I need a table saw?
    Dec 2008
    Santa Claus, In
    4,779
    Just like the title says, why does one really need a table saw? I can cut dados with a router. I can break down sheet goods with a track saw. What can a TS do that something else can't?
    The only thing I can't figure out right now is tenons. Other than that, I can't think of anything.
    I am really thinking of selling mine to make more room.
    13,427
    Repeatability of cut for ripping things to a certain width?
    Working accurately and safely with small pieces on a sled?
    Bevel cuts?
    Nice big flat piece of iron for setting things on?
    You'll still need room to setup a table for your track saw...
    Yorktown, Virginia
    5,074
    Where else are you gonna put your stuff'?? If you have a miter saw, you might do without the table saw, but it really depends on the kind of work you do. I used to use it for ripping long, narrow stock for making custom moldings. Now I use my much safer band saw for most ripping. It works for tenons too. Table saw makes custom cove moldings that would be difficult otherwise. I break down sheet goods with the track saw but still use the table saw with a sled on smaller pieces like drawer parts or small box parts or, if you are a turner, segments for bowls. I also use a miter sled for small box sides and another sled for cutting splines in box corners. I'm not ready to part with mine yet, but it's value really depends on what you build.
    Aug 2011
    Hitchins, Kentucky (Northeastern part of the state.)
    80
    Steve, if you are building all the types of projects that you would like to, and you find the other tools handle those projects without any problem, then you probably won't miss the table saw. But as soon as you get rid of it, you'll need it. That's how things work for me...
    May 2011
    Cape Cod, Ma.
    1,553
    I have routers and shapers and track saws and miter saws and a radial arm saw and skill saws and jig saws... well you get the picture.
    And I would be lost without my table saw. I find it far easier to size sheet goods than the track saw, far more accurate for dados than a router jig especially for case work. I do all my cross cutting and cut my stiles and rails for my doors and face frames on the ts. I very very rarely use my miter saw in the shop.
    Think of the time it takes to set up each cut with a track saw or a router dado jig? then look how fast you can just measure out the fence and depth of cut and cut all your pieces accordingly.
    The TS is the backbone of my shop. I couldnt do without it
    13,427
    One option might be downsizing your saw if.
    I don't know what you have right now, but you could always swap it out for one of the jobsite type saws that you could easily roll out of the way and roll it back when you want to use it.
    13,604
    I'd miss doing the cool pop can ring patterns on top of mine.
    The track saw could possibly do the same job, but overall I think ripping would be easier with the TS. I've done a lot of shelving and cabinet work with just a skill saw, router, and jig saw, but the quality was nothing like when using a TS.
    To a small child, the perfect granddad is unafraid of big dogs and fierce storms but absolutely terrified of the word ďboo.Ē Ė Robert Brault
    NH
    4,023
    Ya don't So you just go ahead and put i in your truck and drive it on out to my house. I wont charge ya a thing for getting rid of it for ya.
    Really i did the same thing a few years back had a junk delta that you couldn't even begin to true up. So it went and I replaced it with the track saw. I have a job site saw for work that has only left my shop once scenes the big saw went. And now I am looking at getting a new cabinet saw (prolly a saw stop)so the job site saw can go back in the trailer.
    Stupid hurts.
    17,494
    chuck he has a stone table that is not right!!!!! and his only alternative is to get a new iron one or get a saw with a correct table.. i couldnt belive it till i saw it in action the groves arent parrell at all.. the miter guage wont even run threw them the same if i was him i would sell it to some poor soul and get a good one never would i be without one steve
    Dec 2008
    Santa Claus, In
    4,779
    Yes Larry has seen the saw. Ridgid 4511. I liked it for a couple of days.
    Basically I just need room. I can't build on, to much other stuff needs done. I am going to play around with location and see what I can do.
  1. Communion Table & Stands - Large table done!
    Last Post: 06-03-2010, 07:30 AM
  2. A Lego table to go with the chairs and drawing table that I made last year
    Last Post: 12-15-2009, 02:37 PM
  3. Chamfer using Router Table or Table Saw
    Last Post: 06-29-2008, 02:45 PM
  4. pool table/dining table input welcomed
    By Robert Schaubhut in forum Designs, Plans and Sketches
    Last Post: 05-22-2008, 02:31 AM
  5. Table Saw. Band Saw. Router Table. *** ALL SOLD ***
    By Rob Bodenschatz in forum Old Ads
    Last Post: 05-31-2007, 04:56 PM
