Results 1 to 7 of 7
Thread: Walker Turner thrust guide bearing retrofit ( an easy way)
    Central PA
    638
    I bought a 14" WT metal/wood bandsaw and took it all apart, repainted, re-tired the wheels. One of the guide thrust bearings was missing and the other was shot so I had to replace them. As with other WT bandsaws the thrust bearings are a non standard size. I did like someone (I think Bob Vaughn) recommended and made a new post for a 6203 bearing to mount on. Usually the post are machined from bar stock with one end machined to 17mm for the bearing to go on and the other end to 1/2" so fit into the rest of the buide block holder. The problem is I don't have a metal lathe to make these on. This is what I did. I took a piece of 1/2" round bar stock and threaded about 1" of it. Then I threaded 2 nuts onto it and tightened them against each other. I chucked this into my drill press and used that as a lathe. I used an angle grinder as the turning tool and rounded the 2 nuts. I left a small section 3/4" in diameter for the back of the bearing to mate against and turned the rest of the nut down to 17mm for a press fit for the bearing. I also ground a flat on the 1/2" section. I think they turned out well and they fit nicely. I was going to just use a 1/2" bolt and cut the head off but bolt diameters are a little undersized so it would have beed a little sloppy in the guide holder which probably wouldn't be a problem, but I had some 1/2" bar stock and a tap and die set so I just did it this way.
    Attached Thumbnails Attached Thumbnails IMG_0206.jpg   IMG_0207.jpg   IMG_0208.jpg   IMG_0209.jpg   IMG_0211.jpg
    Honolulu, Hawaii
    1,103
    Nice work Dave.
    The "Easy way"?, I don't think there are many of us that could produce the results the way
    you did.
    I would even have to take my time doing it on my metal lathe.
    Good job.
    Ah,,,to live in Paradise!
    Registered voting member
    30,014
    That's pretty impressive machining for a drill press and an angle grinder. Nicely done, Dave.
    That's a marvelous piece of ingenuity.
    10,604
    I agree, pretty impressive.
    Central PA
    638
    I forgot to say that I also used a file and some sand paper, I guess its not so impressive anymore.
    13,360
    Nope. Still very impressive Dave!
  1. Walker Turner 14" Bandsaw
    By Dave Black in forum Old Iron
    Last Post: 09-01-2012, 01:12 AM
  2. Walker Turner gear needed
    By Jim Evatt in forum Old Iron
    Last Post: 07-04-2011, 03:09 AM
  3. Walker turner TS
    By Al killian in forum Old Iron
    Last Post: 04-12-2011, 05:30 PM
  4. Walker-Turner tablesaw
    By Frank Fusco in forum Old Iron
    Last Post: 01-08-2007, 06:23 PM
  5. Walker Turner 16" Bandsaw
    By M Toupin in forum Old Iron
    Last Post: 01-01-2007, 01:45 PM
