Results 1 to 7 of 7
Thread: Looking for advice: simple veneer repair
    Oct 2007
    Nova Scotia, 45N 64W
    1,245
    Hello Everyone
    We picked up a solid old government desk (mostly maple) for our son's place at college.
    The drawer fronts are veneer and the center one (about 24" wide, maybe 3" high) is pretty beat up. This is new territory for me, so I'm looking for a few pointers on:
    1) best way to strip off the old busted veneer
    2) simplest way to prepare a new piece (bandsaw, thickness planer?)
    3) is regular cabinetmakers glue fine for this?
    This has already turned from "just a decent old desk for college" to a project. I'm not really looking to work on it until Christmas either! Got enough to do already
    Any advice much appreciated, as always.
    Thanks and best regards
    Peter
    Villa Park, CA
    1,407
    Assuming it's standard 1/42" veneer, the best way to get it off is to sand it off with coarse sandpaper (in a powered sander, belt or ROS).
    The best way to get new veneer is to buy commercial veneer. Woodworking stores, such as Woodcraft and Rockler, used to sell small bundles of veneer. Only problem is that you may only find fancy maple, not plain maple.
    Regular PVA glue will work fine for this but think about how you're going to press it. If the drawer is flat, you can use waxed paper and a caul, clamped with standard clamps.
    Good luck!
    Mike
    Ancora imparo
    Thomasville, GA
    5,994
    Depending on the type of adhesive used, you might be able to remove the old veneer using a heat gun or a regular clothing iron. If that doesn't work, sanding may be the only option.
    Applying new veneer to an item the size of a drawer front can be done by ironing it on. I have a tutorial page on the process here.
    Bill Arnold
    May 2011
    So. Florida
    268
    If it's just a drawer blank, why not just use solid stock for a new drawer front.
    Villa Park, CA
    1,407
    Quote Originally Posted by mike marvel View Post
    Good suggestion.
    Mike
    Ancora imparo
    810
    Oct 2007
    1,245
    Thank you for those suggestions guys.
    I'll look at the new drawer front option, but that will involve dis-assembling the half-blind dovetails. Leaning toward Mike's "grind off the old veneer and re-apply" approach. Don't have a lot of time to spend on this.
    I'll let you know how it goes.
    Have a great weekend.
    Peter
  1. Triple veneer pen
    By Terry Quiram in forum Lathe Project Showcase
    Last Post: 10-01-2014, 12:15 AM
  2. Veneer hand saw
    By Rob Keeble in forum Neander Tool Questions and Show & Tell
    Last Post: 11-04-2013, 07:12 PM
  3. PSA veneer on pine
    Last Post: 10-10-2012, 05:41 PM
  4. pen box? anyone have plans for a simple wooden box, really simple?
    By allen levine in forum Turning Tool Questions and Show & Tell
    Last Post: 12-11-2009, 06:29 PM
  5. one last veneer question
    By jim capozzi in forum General Woodworking Q&A
    Last Post: 03-27-2007, 11:47 PM
