Thought I would post this here as I thought most of the folks that would use this are using hand tools.
Pretty simple way to accomplish this.
Just a question...why couldn't one use a plunge router & a spiral up cut bit?
I have done it several ways. The plunge router is tops in my experience. I really like his built in backer board on the guide. That was always a clumsy issue for me; clamping on a separate backer. I am just now considering more dog holes so this comes at a great time. Many thanks Rich.
Be excellent to each other. - Rufus
Stand firm for what you believe in until, and unless, logic and experience prove you wrong.
What is the common spacing for Dog holes 6"?
I'm thinking with the plunge router mounted to a jig the would center the router every 6" or so on pre-drawn indexing lines then clamped down this would be real easy.
dont see why that wouldnt work Bart. In his video he spaced his dog holes 3-1/2 oc.
I just finished a dozen at 6" http://www.familywoodworking.org/for...ad.php?t=25195
I used a brace and bit to drill the dog holes in my bench. The top is almost 4" thick and it was the only tool I had to drill that deep. I then went underneath to relieve the holes so the hold downs could wedge and lock in properly.
OK, dog holes aren't something I'm familiar with, so help me a little here. The Workmate table by B&D has 3/4" holes in it, as do my Jobmate work tables from Canadian Tire. The only things I have to put in the holes are some stop blocks about 3/4" high. What else can I get to put in the holes, and where would I shop for them? I am going to make some low-profile stoppers to allow me to plane some thin stock, but what else is around?
Thanks
