Results 1 to 6 of 6
Thread: Spalting and coating
    12,251
    Some time back i turned a bowl that has some spalting starting.
    Does the process continue after one has coated the wood. I used wipe on poly at the time and i am pretty sure this mould has grown greater than what was there when i had originally finished it.
    If i am correct and its possible how do you stop it and should i be concerned at all?
    I would have thought the rot needed air from somewhere to grow?
    Any thoughts would be appreciated.
    Jul 2007
    DSM, IA
    5,719
    Rob, I don't think I've seen spalting continue after I've turned a bowl...Usually once the bowl is done it's pretty dry. Do you have any before and after pics? I would think microwaving the bowl might dry it out completely, but that would also hurt the poly finish...
    My Website
    North West Indiana
    6,098
    Is 100% of the bowl finished? The bottom of the bowl/foot would allow air movement if you did not finish this area.
    Jon
    12,251
    I found some pics of it from when i finished i am going to print it and compare. I think its my perception thats a problem here. Somehow i did not remember that much black in it. I will ask my wife to do the judging.
    Goodland, Kansas
    4,834
    Rob I have never had any spalted wood continue to spalt after I apply the finish. Wood is to dry.
    Bernie W.
    30,014
    Ditto the others. I'm pretty certain spalting stops once the wood is dry and finished.
  1. Spalting
    By Ted Calver in forum General Woodworking Q&A
    Last Post: 05-08-2014, 07:04 PM
  2. Spalting pile and some quartersawn red oak
    By John Daugherty in forum Flatwork Project Showcase
    Last Post: 01-02-2012, 10:41 PM
  3. Clear coating Pine tongue and groove walls
    By Roy Cooper in forum General Woodworking Q&A
    Last Post: 06-07-2011, 12:53 AM
  4. Truck bed coating on wood
    By Dave Black in forum Finishing School
    Last Post: 03-13-2011, 02:29 PM
  5. How long does spalting take?
    By Chuck Rodekohr in forum General Woodturning Q&A
    Last Post: 09-15-2009, 12:30 AM
