Results 1 to 10 of 28
Thread: Computer hookup question
    Steve Clardy Guest
    Question Computer hookup question
    Can I hook two computer boxes together by USB cable and everything operate properly?
    Main box would show box two as another drive?
    I've tried the cat5 cable hookup.
    I have not been able to get them to reconize each other. I'm tired of that approach. Both run XP Pro
    Tokiwadai, Japan
    2,882
    Steve,
    Did you use the correct Cat 5 cable? There's an "Ethernet" cable and a "Crossover" cable, IIRC. One may work while the other won't... (Sorry, I'm a Mac guy and things work different/easier...)
    I don't think USB will work...
    New Zealand
    97
    You can get USB networking cables, but I've never used them
    The Cat5 cable is the way to go, but if there are just 2 PCs on the network you have to set up the IP address manually (the default is auto IP allocation) and change the firewall setting to allow file and print sharing. Setting the workgroup id to the same name helps too. If you dont have a network hub you will need a crossover patch lead between the 2 PCs, not a normal one.
    It will be one of these things that stopped it working
    Cheers
    Ian
    Steve Clardy Guest
    Quote Originally Posted by Greg Cook View Post
    Steve,
    OK. Lets see. I have a Cat5E cable I bought several years ago.
    Plugs look like an oversized telephone cable plug.
    Steve Clardy Guest
    Quote Originally Posted by Ian Abraham View Post
    Cheers
    Ian
    I have no network [a seperate box?]. Just the cable.
    Both have ethernet plugins on back.
    Tokiwadai, Japan
    2,882
    Steve,
    If you just want to connect the two together, you need a crossover configured cable.
    This might help...
    http://www.duxcw.com/digest/Howto/ne...ble/cable1.htm
    Checking the cable:
    http://www.duxcw.com/digest/Howto/ne...ble/cable5.htm
    Connecting 2 computers
    http://compnetworking.about.com/od/h...ecttwocomp.htm
    New Springfield OH
    806
    I saw that title and thought you where looking for a date for your computer
    1,289
    Steve, hold the cable ends together. If they are exactly alike it is an Ethernet cable. If the ends are exact opposites it is a cross over cable. You want the to use a crossover cable to connect two PC's.
    Have a look here:
    http://www.kelsoconsultinggroup.com/...2computers.asp
    Don
    Tokiwadai, Japan
    2,882
    Excellent, Don...
    I've bookmarked you link myself..
    Steve Clardy Guest
    Ok!!! So thats the whole problem.
    I have a cat5E ethernet cable
    Both ends are the same
    Edit. The plastic plugs are the same, but the wires are crossed. ??
    I'll go check the links guys. Thanks
  1. Computer Speed Question
    Last Post: 11-21-2014, 05:48 AM
  2. Computer Question
    By Paul Douglass in forum Off Topic Discussion
    Last Post: 09-16-2014, 06:26 PM
  3. Computer Question
    Last Post: 03-02-2013, 12:24 AM
  4. Computer Techie Question
    Last Post: 09-12-2011, 10:47 PM
    Last Post: 08-21-2007, 05:30 AM
